September 18, 2026, 01:20:01 pm
Hoffman Amps Forum image Author Topic: Transformer for Trainwreck  (Read 8380 times)
Offline Oddvar
« on: August 07, 2019, 04:28:03 am »
I am at the moment putting together a Trainwreck Express amplifier.  I have in the drawer a Ted Weber 022798int transformer, 40w.  I was wondering if I could use this?  Toneslut specifics for a TW transformer is:
    Primary: 240V
    HV Taps: 300 - 260 - 0 - 260 - 300 (300mA)
    Heater Tap: 6.3V (7.5A)
    Rectifier Tap: 5V (3A)
The weber specifics on the pic.
Might not be a purist choice, but would it work?
Re: Transformer for Trainwreck
« Reply #1 on: August 07, 2019, 08:15:39 am »
« Reply #2 on: August 07, 2019, 10:20:00 am »
Offline MFowler
« Reply #3 on: August 08, 2019, 09:38:11 am »
I'm an Ampgarage nut and I would use that PT.
My favorite is to build Trainwreck Express 1-12" combo amps using the 18w Marshall style channel chassis using Mojotone Heyboer laydown JTM45 low voltage PT 300-0-300 and 6k open frame 40-18088 Classictone OT and change the Presence to treble cut instead.
Mark
« Reply #4 on: August 08, 2019, 10:34:18 am »
Just want to make sure you're seeing this correctly..
The specs he listed are different than the specs he has which are in the pic.
He has 330-0-330 or 360-0-360, based on the pic
Offline MFowler
« Reply #5 on: August 24, 2019, 04:39:04 pm »
Yes I saw that and nothing wrong with increasing plate voltage and getting some head room.  The Express is dirty right away with that low plate voltage.
« Reply #6 on: August 26, 2019, 09:00:01 am »
But Mark, then you cannot go and buy a DYMO label maker and give it chic's name.  I have built a few and never used Sprague Filter Caps.  No perf boards, made all of them from Beige Fiberglass.  I even built one using different caps throughout, but correct values.  I have never used silicone to hold down caps.  Hate it.  I strap them with metal I form around the cap.
I willl even use my preferred cap cans.
When I get done, I turn it up, find the 2 or 3 problems.
It is not a True Trainwreck, but unless Ken Fisher built it, it never will be anyway.
{EDIT} untangled quote tags - PRR
« Last Edit: August 26, 2019, 08:05:47 pm by PRR »
Offline MFowler
« Reply #7 on: August 26, 2019, 09:51:47 am »
Ed,
Exactly, build it your way and that is what I do as well.
I made one traditional clone then the rest were all my own versions and I don't think I used the same caps twice!
Just have fun guys that's the most important.
Mark
