September 08, 2026, 03:38:24 pm
Hoffman Amps Forum image Author Topic: Kima Marazm's image files  (Read 24988 times)
« on: August 15, 2019, 09:06:13 am »
Kima Marazm on facebook created a bunch of images you can add to DIYLC
The images look funky when you open them in an image editor, but when you add them to DIYLC, they look great
UPDATE: I attached a new zip file to this post with his image files
So far he has created 8 pin, 9 pin, chokes and switches
I also attached my 9 pin belton .diy test file shown in this post
Here's what one of them looks like in DIYLC
« Last Edit: August 16, 2019, 07:11:36 am by EL34 »
Re: Kima Marazm's image files
« Reply #1 on: August 15, 2019, 09:07:54 am »
How to use the images in DIYLC
In DIYLC - Misc Folder - Image- paste it on the work space
Double click the small image to open the Edit selection box
Click to load image file
Navigate to the image file on your computer
« Last Edit: August 15, 2019, 09:15:56 am by EL34 »
« Reply #2 on: August 15, 2019, 09:09:12 am »
If you add colored dots to the pins, then you can stick wires to the dots.
Then group the the image and the dots and the dots will move and stay put on the image.
Select the image and dots - Right click - Transform selection - Group Selection
« Reply #3 on: August 15, 2019, 09:10:20 am »
Once you have grouped the pin dots and the image, you can then save the whole thing as a building block
Now you can paste the building block into any DIYLC file
« Reply #4 on: August 15, 2019, 09:11:31 am »
Add wires to the dots on the socket.
You can make the wires stick to the dots and then you can move things around and everything will move and stay stuck to the pins on the socket.
In the config menu, if you check sticky points, you can move the socket around and the wires will stick to the dots and everything will move at the same time
