August 29, 2026, 04:58:16 pm
Hoffman Amps Forum image Author Topic: 3-way relay with footswitch  (Read 5368 times)
Offline isaac_teller
« on: September 09, 2019, 09:04:12 am »
Hello. How would I implement a 3-way footswitch(clean, overdrive and distortion channels) on a TRex type amp? Has anyone ever done this? Shematic? Thank you
Re: 3-way relay with footswitch
« Reply #1 on: September 09, 2019, 09:40:22 am »
TRex type amp?
Got a schematic for that?
« Reply #2 on: September 09, 2019, 09:41:35 am »
« Reply #3 on: September 09, 2019, 09:55:24 am »
There are only two channels. An A/B switch on the inputs would be easy.
« Reply #4 on: September 09, 2019, 11:29:32 am »
I want to add a high-gain addition to the clean channel. For example:
« Last Edit: September 09, 2019, 11:35:30 am by isaac_teller »
Offline d95err
« Reply #5 on: September 18, 2019, 06:06:44 am »
You would need two relays. E.g. one to switch between the two channels and one to switch one channel between crunch/higain.
For this amp, it would probably be easier to add a separate boost stage to one of the channels, rather than folding one channel back into the other.
If you don’t have another triode to spare, you could add an LND150-based stage.
« Reply #6 on: September 18, 2019, 02:34:17 pm »
Thank you.
