September 08, 2026, 08:08:37 pm
Hoffman Amps Forum image Author Topic: milltronics gig  (Read 34171 times)
milltronics gig
« on: September 09, 2019, 06:14:37 pm »
 was at my Brothers 60th, passing it around all the gray hairs  :laugh:
said something about my career, wound up meeting a tube builder, champ n kit form dynaco(sp?),  Next guy, um you think....
spent some time isolating a problem on one of these
https://www.ebay.com/itm/MILLTRONICS-VM-16-CNC-Vertical-Machining-Center-Mill-COOLANT-THRU-CHIP-CONVEYOR-/143266484600
If anyone has had their fingers in these I'm interested in tips  :laugh:
hoping to pick up at least routine maintenance, it was just great having one with folks you had one with 45yrs ago  :icon_biggrin:
Re: milltronics gig
« Reply #1 on: September 10, 2019, 10:59:59 am »
They came with a variety of controls over the years - I think... proprietary, fanuc, siemans if I remember correctly.  Never heard a bad thing.  They are kind of in the Haas range of capability.  They are chip makers but not as capable as a high end mills like Mori or even a Mazak.  A lot of off the shelf parts but some control boards are specific to Milltronics.  Factory support is legendary.  I would call them.
Re: milltronics gig
« Reply #2 on: September 10, 2019, 01:02:28 pm »
I would call them.
I did, and they were great, talked geek for a few minutes on what I found/did, n ya, happens to be a proprietary part, but have to send back the whole brain!
I did ask if there was anything I needed before I pulled the CPU, nope.  This morning I had to put it back, relearn DOS commands  :think1:
kinda fun getting back to system work.  It's off to the pdf's  :BangHead:
Re: milltronics gig
« Reply #3 on: November 02, 2019, 04:37:51 pm »
chips are flying  :icon_biggrin:
I got the problem close, but don't have the cool kid toys for the system so passed it off to the pro's.  1 Zdrive and 20 parameters tweaked later, joy!
looks like I will land the maintenance contract in the spring, fun with oil, grease n sharp sheet  :think1:
working on an R&D project over the winter.  Shop needs a stand alone automated multi angle light duty (aluminum n plastic) drill (1/16" - 3/16") so the big gear can be freed up.
so got out the modern day outrageously priced erector set so I can work up a controller n software.
maybe I can re-use the proto-type to solder  :icon_biggrin:
Re: milltronics gig
« Reply #4 on: November 03, 2019, 06:53:29 pm »
updated arm
tested 1st joint, needs the worm gear, added, working on 2nd joint  :icon_biggrin:
Re: milltronics gig
« Reply #5 on: November 06, 2019, 04:51:20 pm »
2nd joint working, still need some small tweaks on 1st joint, adding a cheap on-hand servo for joint 3, then it's wiring n software
Re: milltronics gig
« Reply #6 on: November 06, 2019, 06:10:02 pm »
Ok, this project is starting to look like the robot arm Wollowitz built on the Big Bang Theory....  Are you SURE this is for the shop? :think1:
Jim :icon_biggrin:
Re: milltronics gig
« Reply #7 on: November 07, 2019, 08:30:11 am »
 :l2:
one of my straight-laced exec. type friends asked what I was up too last week, told him about the arm, when he asked why, gave him my cheezy smile n told him my own was getting tired  :icon_biggrin:
what Greg needs is a gantry table with extra axes, but I don't have that erector set so i'll get the software dialed n if I'm confident, put together a hardware order with His card  :laugh:
this is my 5-6th bot build, the arm was originally conceived as a tracking platform to launch model rockets, or 4th July mortars at drones  :icon_biggrin:
Re: milltronics gig
« Reply #8 on: November 08, 2019, 06:48:00 pm »
Ok, that looks exactly like this one....
Jim :icon_biggrin:
Re: milltronics gig
« Reply #9 on: November 08, 2019, 07:01:55 pm »
 :laugh:
saw the show, for some reason I equated that show with 3rd rock sitcom
btw, his has 6 joints, I'm a light-weight at 3 (with LOTS of torque:)  :icon_biggrin:
Re: milltronics gig
« Reply #10 on: November 08, 2019, 07:49:14 pm »
Just don't program it for the screwdriver move!
Jim :laugh:
Re: milltronics gig
« Reply #11 on: November 09, 2019, 04:57:57 pm »
:laugh:
I code like I "design" amps, steal cool stuff, stitch together, call it mine-ish  :icon_biggrin:
feel free to edit what I have so far, which is nothing  :l2:
(didn't bother formatting the txt file so there's wrap around)
Re: milltronics gig
« Reply #12 on: December 23, 2019, 12:43:00 pm »
the things you forget  :think1:
been over 40yrs since I last laced anything, not a very good comeback but hey, I'm trying  :laugh:
I blame it on the So. GA chiggers I'm combating  :cussing:
Re: milltronics gig
« Reply #13 on: December 23, 2019, 07:19:41 pm »
Finished the octopus, wired it to the uP board, not authorized for LVpower til morning  :icon_biggrin:
software  :cussing:
Re: milltronics gig
« Reply #14 on: December 23, 2019, 07:50:52 pm »
Looks like a big light dimmer!    :l2:
Re: milltronics gig
« Reply #15 on: December 23, 2019, 09:09:45 pm »
The tea bottle for overflow lube?
Jim  :icon_biggrin:
Re: milltronics gig
« Reply #16 on: December 24, 2019, 05:43:42 am »
a big light dimmer
overflow lube?
It's my camo-bong  :icon_biggrin:
those motor controllers are fused at 25A ea, that's ALOT of dimming  :icon_biggrin:
Re: milltronics gig
« Reply #17 on: January 17, 2020, 02:16:39 pm »
got tired of holding n swapping wires to switch direction  :think1:
cobbling a PS together that will power the uP board (9vdc) and the motors (12vdc)
the cute C_made boards were $8!
still need to load test, add some front panel switches for direction, n more
both boards read 98.2% of Fluke so that's a good start
Re: milltronics gig
« Reply #18 on: January 18, 2020, 09:51:29 am »
Jim :icon_biggrin:
"'cause that's all you needed, right?"   :laugh: :l2:
Re: milltronics gig
« Reply #19 on: January 18, 2020, 11:25:57 am »
I'm in So. Fl, you can find humans WAY less expensive than this project  :icon_biggrin:
Gotta say not many ppl stop and ask questions though and I shower every day  :dontknow:
Re: milltronics gig
« Reply #20 on: January 18, 2020, 07:24:07 pm »
That episode is such a classic!
Jim :l2:
