August 29, 2026, 04:57:24 pm
Hoffman Amps Forum image Author Topic: Four inputs on JTM45 vs single on Plexi 6V6  (Read 4282 times)
Offline dude
« on: September 29, 2019, 01:21:50 pm »
A JTM45 with four inputs, hi/low each channel, is jumping the channels basically the same as using the single  input on a Plexi 6V6?  Both volumes on both amps can then be blended, would that capability produce the same tone? I assume on the 6V6 Plexi turning one volume down to 0, would be turning off that channel or the same as just using the JTM45’s same channel...?
Re: Four inputs on JTM45 vs single on Plexi 6V6
« Reply #1 on: September 29, 2019, 01:51:23 pm »
The 6V6Plexi is modeled after the JMP 1987, not the JTM45 series. Slightly different. But they all operate basically the same as far as jumping channels and blending volume controls.
