September 09, 2026, 08:27:03 am
Hoffman Amps Forum image Author Topic: Speaker Mounting Screw  (Read 10510 times)
Offline dbishopbliss
    • Bliss Amplifiers
« on: September 30, 2019, 07:57:47 pm »
I have some of the Fender style speaker mounting screws with the wood and machine thread. Do I simply drill a pilot hole large enough for the machine thread to go through and then the wood thread will bite into the baffle? Or, should the pilot hole be slightly smaller than the machine thread? Anyone know what size drill bit to use off hand?
I know I could use T-nuts, but I already have these and I am trying to replicate the Silvertone 1482 construction - just using quality materials.
Check out my blog for more details. Bliss Amplifiers
Re: Speaker Mounting Screw
« Reply #1 on: September 30, 2019, 09:01:04 pm »
There's charts for this online - for wood I just eyeball it.  For wood I make the pilot hole the diameter of the inside shank of the screw (excluding the threads).  Typically I make the pilot hole too small; then have to enlarge it.  :cussing:
« Reply #2 on: September 30, 2019, 09:38:20 pm »
Yes. The screw is typically 8-32 machine threads and reverse #10 wood threads. Drill for a snug fit for the 8-32. The #10 wood screw will bite. Don't forget they are left handed threads!
« Last Edit: September 30, 2019, 09:59:13 pm by sluckey »
    • Bliss Amplifiers
« Reply #3 on: October 09, 2019, 12:38:24 pm »
Not sure where I got my screws from (I thought it was Hoffman) but they are NOT left-handed. I was trying to screw them in last night and they were not biting at all. Then I turned the drill to regular and they screwed right it.  :dontknow:
Offline dude
« Reply #4 on: January 04, 2020, 10:27:41 am »
Those Fender style speakers screws are OK, but I find they're usually too long, takes forever to change speakers  :icon_biggrin: .
Also, you have to be careful to get them straight, or when you put the speakers in you scrape the sides of the threads, I learned the hard way. I glue them in sometimes if I use a half inch baffle too.
