August 29, 2026, 04:58:16 pm
Hoffman Amps Forum image Author Topic: Output Impedance question  (Read 4100 times)
Offline Jonas
« on: October 05, 2019, 12:58:17 pm »
Hi Everyone,
I need help clearing up some confusion...........
I have a push-pull amp with 4 tubes.  The OT is 2K primary and 4, 8, 16 ohm secondary with 8 ohm tap connected to 8 ohm speaker.
If I connect the 8 ohm tap to a 4 ohm speaker, would the tubes now "see" 4K?
If I pull (2) tubes, would I need to connect the 16 ohm tap to an 8 ohm speaker to get the tubes to see 4K?
Thanks for your help!!!
Re: Output Impedance question
« Reply #1 on: October 05, 2019, 01:28:54 pm »
the primary winding impedance is based on the load impedance (secondary)
so if you 1/2 the load (secondary), the reflected load (primary) with be 1/2
now pulling 2 tubes your design load is halved, so the actual load needs to be halved to "reflect" that change
I think, I'm a tin-knocker plumber at the moment  :icon_biggrin:
« Reply #2 on: October 05, 2019, 01:33:17 pm »
The impedance reflects back from the speaker (load) impedance.  If an 8 Ohm speaker load produces a 2 Ohm primary impedance; then a 4 Ohm load produces a 1 Ohm primary impedance.
Yes, an 8 Ohm load on the 4 Ohm secondary tap > 4 Ohm on this primary.  This matches the two tubes pulled scenario.
EDIT:  shooter -- pulling 2 tubes doubles the "output impedance of the remaining tubes.
« Last Edit: October 05, 2019, 01:35:24 pm by jjasilli »
« Reply #3 on: October 05, 2019, 05:14:06 pm »
> OT is 2K primary and 4, 8, 16 ohm secondary with 8 ohm tap connected to 8 ohm speaker. If I connect the 8 ohm tap to a 4 ohm speaker, would the tubes now "see" 4K? If I pull (2) tubes, would I need to connect the 16 ohm tap to an 8 ohm speaker to get the tubes to see 4K?
This is all *backward*.
