August 29, 2026, 04:58:27 pm
Hoffman Amps Forum image Author Topic: New bias board  (Read 5022 times)
Offline Swampertech
New bias board
« on: October 10, 2019, 09:02:53 am »
Hey Doug, I'd like to create a new bias board, but your program doesn't allow a board to be less than 5" long X 3.125" tall. My board would be 2.35" X 3.125". Is there a solution?
Re: New bias board
« Reply #1 on: October 10, 2019, 09:17:06 am »
I had 2 identical circuits laid out n turreted by Doug, then I used the dremel to cut the board in 1/2.
Offline Swampertech
Re: New bias board
« Reply #2 on: October 10, 2019, 09:25:08 am »
Shooter, I saw Doug had some bias boards that were not 5" long. I may have to do as you said and cut them myself.
Re: New bias board
« Reply #3 on: October 10, 2019, 11:00:50 am »
His board cuts easily with a hacksaw. It's been a while, but I ordered a long length and cut-up into four short lengths for a fusebox-conduit hack. I don't remember the slicing; boring the 2" holes was mildly memorable.
Fine tooth blade. A dust-mask is wise.
Re: New bias board
« Reply #4 on: October 10, 2019, 11:21:29 am »
+1       Been doing it that way for yrs...………      easy, quick and little dust
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
Re: New bias board
« Reply #5 on: October 10, 2019, 12:28:59 pm »
Yup agreed, I just did my bias board and my main board on the same turret board and then cut off the bias board.  Worked perfectly for me.
If you don't see any specific need for 'longer' you can just make it the minimum length and leave part of the board empty?  I do make my own now, but because I wanted to try and see how it worked, but having him do it was always TONS easier :D
~Phil
Phil Davis
tUber Nerd =|D
Offline Swampertech
Re: New bias board
« Reply #6 on: October 10, 2019, 12:59:09 pm »
Thanks guys, I just ordered two filter cap boards and two bias boards, laid end to end.
