September 19, 2026, 02:19:53 am
Hoffman Amps Forum image Author Topic: Box of rock  (Read 7813 times)
Offline okguitarman
Box of rock
« on: October 14, 2019, 04:11:25 pm »
 To much low end what can be changed?
Offline MakerDP
Re: Box of rock
« Reply #1 on: October 17, 2019, 10:56:09 am »
You could try looking at the schematic here for how to implement a low-cut switch.
file:///home/chronos/u-74f6638dd087231dd8904d8f0d4a04be22dd4349/MyFiles/Downloads/aion-prism-fa1-documentation.pdf
Offline okguitarman
Re: Box of rock
« Reply #2 on: October 19, 2019, 08:01:24 am »
thanks
Offline smackoj
Re: Box of rock
« Reply #3 on: October 21, 2019, 04:50:43 pm »
hi; i don't know if you are still looking for suggestions? and i assume that your zvex has a pcb that is easy enuff to work with. But a simple and inexpensive way to reduce low hz is to use smaller value caps. You could try reducing the value of the coupling cap C6. that is a polarized cap so replace with something that has positive and negative leads and try one that is at least 1/2 the value of the 1 uf cap.
Re: Box of rock
« Reply #4 on: November 12, 2019, 02:06:07 pm »
OJ is correct but not the only way, just the easiest however an electrolytic is not needed and in fact shouldn't be used anyway. I hate e-lytics in the signal path and they are way too high in value anyway. They are only used in mass produced pedals because they are much less money to use.
