September 14, 2026, 04:19:54 pm
Hoffman Amps Forum image Author Topic: adjustable NFB  (Read 6170 times)
Offline Leevi
    • Rikstone
adjustable NFB
« on: October 18, 2019, 08:59:06 am »
I have an issue with Marshall 1959 type clone. I have added an adjustable NFB pot (250K)
which causes noise maybe because of a DC offset. The noise can be eliminated by adding a cap in series with the pot
but then there comes an low freq. oscillation when the pot is turned off. I have added a 10K fixed resistor in series with the pot
but it doesn't help. Is there any way to get the NFB control  noiseless?
/Leevi
Re: adjustable NFB
« Reply #1 on: October 18, 2019, 09:30:14 am »
I'm looking at this schematic;
https://el34world.com/charts/Schematics/files/Marshall/Marshall_1959_jcm800_super_lead_power_amp_100watt_year_1988.gif
I believe presence is a form of NFB?
If you're adding another loop that will probably be problematic.
Offline Leevi
    • Rikstone
Re: adjustable NFB
« Reply #2 on: October 18, 2019, 11:57:54 am »
The NFB wiring is like in the linked schematic. Presence control does not cause any noise. The noise of the NFB pot comes only when turning the pot.
Leevi
Re: adjustable NFB
« Reply #3 on: October 18, 2019, 12:18:45 pm »
You don't want to make R24 much less than 100k, Marshall already dialed-in a lot of NFB and more will be unstable.
Yes, it scratches because there is +25V(?) at one end and zero at the other. The DC current in the wiper "scratches"; and you are upsetting bias on V3.
Use a 47k end-stopper and 0.5u-0.68u series cap. That gives about all the NFB it can stand, blocks DC, and is flat to 5Hz which *may* be enough to avoid instability. (10uFd 50V e-cap is sure to be flat to sub-Hz, and may be cheaper.)
Re: adjustable NFB
« Reply #4 on: October 18, 2019, 01:39:51 pm »
I'll NEVER argue with PRR's assessment  :laugh:
what is your "intent"?  are you trying to tame a Marshall enough to be a Fender ?  :icon_biggrin:
Re: adjustable NFB
« Reply #5 on: October 18, 2019, 02:09:06 pm »
Is that really a problem? Most of the earlier Marshalls and Fenders have a scratchy presence pot only when turned. But the Presence pot is mostly a "set it and forget it" type control, so no big deal. I suspect your variable NFB will also become a "set it and forget it" control in about a week. I'd just let it be.
Offline Leevi
    • Rikstone
Re: adjustable NFB
« Reply #6 on: October 18, 2019, 02:56:39 pm »
That works fine, thanks PRR. I used a 680n cap and the end-stopper can be even smaller than 47K (22K) and works fine.
It's maybe good to mention that the amp is using 2 power tubes instead of 4 which probably has some meaning in this.
I agree, it is not a problem for me but there are people that don't accept any scratchy pots :laugh:
/Leevi
« Last Edit: October 18, 2019, 05:02:40 pm by Leevi »
