September 14, 2026, 05:13:48 pm
Hoffman Amps Forum image Author Topic: Adjustable Bias and universal output tube setups....  (Read 4754 times)
Offline 1blueheron
« on: October 22, 2019, 09:03:07 am »
I am interested in building an amp that can utilize 6V6, 6L6, EL84, EL34 KT66, KT88 with relative ease if possible.  I would like to use my salvaged Wurlitzer organ amp for donor iron which was a PP 6L6 amp.
I have read that there are amps out there that can do this, such as the Allens, Mesa, Komet etc.
I like what I am hearing from the Komet 60 but can't find a schema for it.  Any suggestions for this project appreciated.
Thanks.
Re: Adjustable Bias and universal output tube setups....
« Reply #1 on: October 22, 2019, 09:54:15 am »
SE or PP?
I probably wouldn't attempt it myself, too much work for too little change, IF I did try, I'd build it for the '88 running happy then go back n hack it up
Offline 1blueheron
« Reply #2 on: October 22, 2019, 10:13:23 am »
Preferrably PP as I believe the OT for my Wurly is for PP.
« Reply #3 on: October 22, 2019, 11:48:52 am »
If 6V6 and EL84 are expected to run with 6L6 loading, aim for 300V-330V B+ and don't expect over 15 Watts.
The big tubes are a different class than the little tubes.
