August 29, 2026, 04:56:00 pm
Hoffman Amps Forum image Author Topic: More dual secondary questions...  (Read 5186 times)
Offline 1blueheron
« on: October 29, 2019, 09:31:19 pm »
Since we seem to be on the topic of dual secondaries... I pulled out the Conn amp that I put away several months ago with a burned out 5y3gt.  I found another 5y3gt in it and powered up to take some readings on the PT.  This amp has dual secondaries.  One feeds a 5u4 and appears to be 300-0-300 (311-0-311VAC on 121V primary).  The other one feeds a 5Y3GT and I am seeing 384-0-384VAC (345-0-345 adjusted for 121V?)
Rectified output without load measured 400/400VDC on the 5U4 and 458/430VDC on the 5Y3GT.
Originally I was going to make a Reverberocket out of it, now I am wanting to build a Marshallesque 2204ish type amp.  It seems like this PT is a closer match for this purpose than the PT from the Wurlitzer which is kicking out 460VAC.
I am thinking I could actually build an all octal version ( V1=6F5, V2=6F5, V3=6SL7, V4=6SN7, V5=6L6, V6=6L6)  and a standard version with 3-12AX7A's and 2-EL34's on the same chassis and be able to switch between the two depending on the tone desired.
It might be kinda cool?  Has anyone tried this using a dual secondary PT or does it sound like a bad idea?   Chassis was originally set up for a quad of 12V6 and a pair of 6V6 as well as 4 noval sockets.  The chassis has a pretty similar layout to a marshall plexi.
About the time I got the voltage readings off the rectifier tubes a capacitor decided make like an Indian and let out some smoke signals.  Things got a little exciting. Sent wife went running. At first wisp of smoke I pulled the power but it had enough heat in the cap to blow the bottom out and spew oil. :w2:  Stunk pretty bad and was a mess to clean up but don't think any damage was done.  Will definitely need a re-cap.
Re: More dual secondary questions...
« Reply #1 on: October 29, 2019, 11:13:23 pm »
> the Conn amp
Which Conn amp?
Offline 1blueheron
« Reply #2 on: October 30, 2019, 06:34:47 am »
Once again I left out a key piece of info didn't I. :BangHead:
OK, It is out of a Conn "Serenade".  Model #621-F.
It was exactly a year ago yesterday I picked it up and have had it stashed beside the bench.
Here was the original thread with pictures etc..
https://el34world.com/Forum/index.php?topic=23884.msg257462#msg257462
Project was abandoned when Sluckey encouraged me to get more experience with a simple amp first and so I went that direction rather than cutting this one up.  Now I am ready to take another stab at it and now I feel like the chassis layout and transformer would be better for a marshall than Ampeg.  Felt it would be better to start a new thread.
« Reply #3 on: October 30, 2019, 12:40:34 pm »
Schematic of related amp:
https://el34world.com/Forum/index.php?action=dlattach;topic=23884.0;attach=73660;image
That one runs two 6L6 and the flock of V6es. Is yours actually 6V6es in the main channel? (The 400V argues this amp was 6L6.)
Offline 1blueheron
« Reply #4 on: October 31, 2019, 05:55:29 am »
Chassis was originally set up for a quad of 12V6 and a pair of 6V6 6L6 as well as 4  5 noval sockets.  The chassis has a pretty similar layout to a marshall plexi.
See edit above...
I began verifying the schematic against the actual amp last night.  I got through the main section and only found 2 things different other than the single 15" speaker.
R15 = 2.7K
R22 = 15K
Hope to get through the rest of it tonite when I get off work.
« Last Edit: October 31, 2019, 06:01:06 am by 1blueheron »
« Reply #5 on: October 31, 2019, 08:51:24 pm »
> R15 = 2.7K  R22 = 15K
R15 is slightly lower minimum volume (for some reason the volume does not go to zero; you might decide it should).
R22 may be slightly better P-P balance, but depends on tubes (or tube-lot for a manufacturer), and balance is not a must-have in a guitar amplifier.
With the new tube line-up it does look like you could run four 6L6. Or six (or eight!) 6V6 (with appropriate heater connection). Sadly not four EL34.
Offline 1blueheron
« Reply #6 on: November 01, 2019, 09:01:56 pm »
Thanks PRR,
I verified the rest of the schematic and it checks out.
So if I do one side all octal 6F5>6F5>6SL7>6SN7>2- 6L6GB fed off the red green pair and the other side 12AX7>12AX7>12AX7 > 4- 12V6 or 2-EL84 fed off the red pair, with only one half the amplifier being driven at any given time (channel selected with a foot switch and directing input from one side to the other),  would this be reasonable?
  I realize the OT for one side may be inadequate and require an additional OT be purchased unless the 6L6 OT could be shared somehow.
