September 15, 2026, 05:03:26 pm
Hoffman Amps Forum image Author Topic: Electrohome Hi Fi Chassis ECL86 SE  (Read 4621 times)
Offline Rusty
« on: November 03, 2019, 01:24:55 pm »
Greetings,
My second post on the forum... So after introductions I figured I would post what I can't really claim I've built, more like boiled down from a full console Hi Fi chassis receiver to just a stereo amplifier.
Uses a pair of ECL86s (originally 6GW8s) and a voltage doubler off the power transformer's 100 VAC output to make about 2.5 W per channel.  It's been my first foray into tube territory and I have ordered a quad of Chinese EL34s to build a push-pull unit with a bit more grunt.
I had no schematic to work with, so as I removed the RF tuner portion I would occasionally power the unit up to make sure it was still working.  Lots of caps have been replaced but so far the electrolytics are still OK.
I have noticed that one of the cathode bypass resistors has aged and 'worn' from the 150 ohm markings to 170.  I removed the tone controls and put in a newer volume pot and knob.  It's not boutique, but I like it.
Anyway as I acquire more for the EL34 build I will post my ideas and questions and see what gives.
Offline Pietro
  • I love everything thats vintage. Even my mom!
Re: Electrohome Hi Fi Chassis ECL86 SE
« Reply #1 on: November 05, 2019, 06:40:36 pm »
cool. Do you plan to draw up a final schematic? I.m quite cursious .
grtz
I love everything that's vintage. Even my mom!
Offline Rusty
« Reply #2 on: November 06, 2019, 08:44:44 am »
grtz
I have not scratched out a schematic for the ECL86 chassis, but I should.  I will post it here.  If you refer to the EL34 p/p amp, well that is just ideas in my head so far...
