September 16, 2026, 11:19:01 pm
Hoffman Amps Forum image Author Topic: Spitfire Turretboard Layout - Suggestions?  (Read 4308 times)
Offline Cloud10
« on: November 13, 2019, 03:14:28 pm »
I'm using an old layout in JPEG format to make a custom turret board on the Hoffman Amps design page. I took a screenshot of my attempt at a layout and attached it as well. Can anyone take a look and suggest any changes you would make? Areas that could use extra room? This will be my first amp build and I want to avoid botching it from the beginning. Thank you.
Re: Spitfire Turretboard Layout - Suggestions?
« Reply #1 on: November 13, 2019, 04:11:32 pm »
Some are spot-on, some close-enough. But I see missing dots column 18-19 and 24, 27. Under the big caps I see a big resistor on a small spacing, or else a pin where no pin is needed.
