September 17, 2026, 06:11:50 am
Hoffman Amps Forum image Author Topic: Pro Junior - Hand Wired Mod Difficulty  (Read 8979 times)
Offline specialk13
« on: November 21, 2019, 10:43:11 am »
Hello, this is my first post and hopefully, one of many if I get this project going :)
My question is, how difficult is it to do the hand wired conversion on a Pro Junior? Is it more difficult than say a 5E3 kit build? I have performed some modifications to amps in the past and have a lot of soldering experience but this would be my first PTP board.
I don't need to be persuaded not to do this but I also don't want to go ahead with it if it's considered a difficult project for someone with my skill set. I also have the perfect donor amp, which is why I'm entertaining the idea instead of going with a new kit.
Thank you!
Re: Pro Junior - Hand Wired Mod Difficulty
« Reply #1 on: November 21, 2019, 11:32:03 am »
it's pretty easy if you put 90% into planning and 10% into building, most of us start the other way around  :icon_biggrin:
by PtP, no turret/eyelet just lugs?
Offline specialk13
« Reply #2 on: November 21, 2019, 11:42:59 am »
Thank you for the reply, I haven't decided 100% but I will probably go with a turret board now that you mention it.
« Reply #3 on: November 21, 2019, 11:52:01 am »
Will you be following Hoffman's plans (or another proven plan) for a Pro Jr. conversion? If so, it should be pretty easy. If not, can you read a schematic and draw a layout based on that schematic?
Offline specialk13
« Reply #4 on: November 21, 2019, 12:00:21 pm »
I would be following the Hoffman plan as I think it has the most complete information.
Offline specialk13
« Reply #5 on: November 24, 2019, 09:11:02 am »
Does anyone have any recommendations on what I can modify to make the amp sound more like a Vox/British amp? That's the direction I would like to go with this one.
« Reply #6 on: November 24, 2019, 09:22:57 am »
I highly recommend this...
     http://sluckeyamps.com/Dual_Lite_(British).pdf
Offline specialk13
« Reply #7 on: November 24, 2019, 09:27:41 am »
Hmm that's quite a divergence from the pro jr layout. I was hoping I could adjust some values, etc. to the Hoffman layout to get there.
« Reply #8 on: November 24, 2019, 09:36:49 am »
Gonna be more involved than just adjusting a value, etc. You could keep most of the Hoffman stuff and just replace his V1 circuit with one of the British preamps shown in my dual lite. I would also convert his fixed bias circuit to the simpler cathode bias circuit.
Offline specialk13
« Reply #9 on: November 24, 2019, 09:49:13 am »
Understood, I'll give that another look. Thanks!
« Reply #10 on: November 24, 2019, 11:57:23 am »
I just took a look at Hoffman's conversion page. That's gonna be a fairly challenging project. I'm gonna back off my suggestions and instead advise you to do the conversion exactly as Hoffman shows. Then once you have a working amp we can talk about mods.
« Reply #11 on: November 24, 2019, 12:14:32 pm »
I missed this statement. Your perfect donor is a Pro Junior, right?
Offline specialk13
« Reply #12 on: November 24, 2019, 01:58:28 pm »
Correct, version IV pro junior.
