September 15, 2026, 06:12:52 pm
Hoffman Amps Forum image Author Topic: Add adjustable bias to Hiwatt DR504  (Read 7593 times)
Offline eahudimac
« on: December 05, 2019, 09:35:18 am »
Hi everyone,
I am building a Hiwatt DR504 clone and have a couple of questions about adding adjustable bias to each tube. First of all, is it even worth it to add adjustable bias to each tube? I will always use matching tubes, so I assume that it is not necessary, but I like the idea of it. I am going by this picture from a dual biased 504 mod and wiring diagram by Mark Huss, which I have attached. For the life of me, I cannot determine what value resistor is connected to the wiper. I know the resistor to ground is 22K. Is it 220K? I'm not sure from looking at the schematic. I intend to install bias test jacks to make this procedure easy in the future.
Any advice on this would be greatly appreciated. Thank you!
Re: Add adjustable bias to Hiwatt DR504
« Reply #1 on: December 05, 2019, 10:03:03 am »
Is it 220K?
yes
Offline eahudimac
« Reply #2 on: December 05, 2019, 03:29:10 pm »
Thanks!
« Reply #3 on: December 06, 2019, 08:50:48 am »
The problem lies in as matched tubes age they can age differently and drift apart. As they drift, bass end becomes less and less, and noise rejection inherent in a PP power stage becomes less and less.
But, a single adjust pot has been the standard, if they have adjustable bias.
I like separate bias pots a lot.
Not much more to add, but do you have room for 2 pots?
I've done that in amps I've built, and like it, but you still need to pull the chassis to get B+ readings as you rebias.
« Last Edit: December 06, 2019, 08:54:11 am by Willabe »
Offline eahudimac
« Reply #4 on: December 06, 2019, 10:23:39 am »
Thank you! I appreciate the advice. I do have room. The chassis is drilled for 4 power tubes. I will only be using two so I have the other to fit bias pots into.
