September 17, 2026, 05:28:35 am
Hoffman Amps Forum image Author Topic: Temporarily muting signal while changing channels.  (Read 7697 times)
Offline Captain chunkulus
« on: December 07, 2019, 09:22:22 pm »
Any of you guys know a simple way temporarily mute a signal while changing channels so the relays don't pop while changing channels? Thanks.
Re: Temporarily muting signal while changing channels.
« Reply #1 on: December 07, 2019, 09:37:58 pm »
cascaded 555 timers configured as one-shots. the first 555 mutes, the second 555 switches. the first timers' time constant longer than the second. ~250ms to mute 100ms switch. better yet; use vactrol opto coupled varistors, such as the VTL5C3, etc..
« Reply #2 on: December 08, 2019, 02:32:29 am »
Better to minimise / cure the ‘pop’ rather than introduce momentary muting circuits?
« Reply #3 on: December 08, 2019, 08:15:06 am »
This seems better to me. I already have relays installed that are switching the channels and such. Just get popping when changing channels. Any simple fixes for this?
« Reply #4 on: December 08, 2019, 09:08:16 am »
Yes, a time delay works, but is not optimal especially when playing live.  One solution may be a 1M R across the SW section of the relay.  This also works for manual SW's.  Another possibility is a snubber diode circuit:  https://en.wikipedia.org/wiki/Flyback_diode
Also see the annexed files.
Offline d95err
« Reply #5 on: December 08, 2019, 10:58:15 am »
If you post schematic, it will be easier to help you.
As for a temporary mute circuit, a simple solution using a fet and rc network triggered by the relay switching is used by some manufacturers. I think Engl amps has this.
« Reply #6 on: December 08, 2019, 11:51:00 am »
This unit is to be put in parallel with the contact of the switch (done for solve your kind of problems - didn't has a high price)
Expecially Read this (and other link)
http://www.kemet.com/Lists/ProductCatalog/Attachments/146/F9000_GenInfo_RCUnits.pdf
https://it.rs-online.com/web/p/condensatori-per-reti-rc/0209213/
http://el34world.com/Forum/index.php?topic=14021.ms
« Last Edit: December 08, 2019, 01:39:01 pm by kagliostro »
« Reply #7 on: December 08, 2019, 01:36:28 pm »
What is an example circuit for the fet/rc network your talking about? Is this it basically?
« Last Edit: December 08, 2019, 01:38:56 pm by Captain chunkulus »
« Reply #8 on: December 08, 2019, 05:32:19 pm »
What is popping - The coil or the audio switched circuit?
The back emf of a dc coil is best de energised with diode; RC snubbers are used for ac coils.
« Reply #9 on: December 08, 2019, 05:44:51 pm »
Well, I'm using a dc supply for the relays and a mechanical switch to make and break the connection to the negative side of the supply.
« Reply #10 on: December 09, 2019, 04:50:05 am »
A dc relay coil needs a (reverse biased) diode connected across it (or between the switched coil end and circuit common), fitted in close proximity.
Any regular power diode should do the job, but as they’re cheap and readily available, these days I’d use UF4007.
The big advantage of dc relays in this application is that its back emf spike can be so easily and effectively mitigated (ie compared to ac coils).
« Last Edit: December 09, 2019, 05:52:09 am by pdf64 »
Offline d95err
« Reply #11 on: December 09, 2019, 06:09:07 am »
Again, without a schematic it's difficult to help you.
Doesn't have to be fancy. Make a simple drawing on paper and take a photo with your phone, then upload here.
« Reply #12 on: December 09, 2019, 06:24:11 am »
+1
