September 16, 2026, 08:34:47 pm
Hoffman Amps Forum image Author Topic: Help! Looking schem for 2 channel JCM800 type with channel switching  (Read 7678 times)
Offline Backwoods Joe
Sorry I can't remember the name of the schematic, but someone on this board has a schem for a 2 channel JCM800 type with channel switching that is tried & true. THX,  joe
Re: Help! Looking schem for 2 channel JCM800 type with channel switching
« Reply #1 on: December 12, 2019, 06:23:57 pm »
Are you maybe referring to my Marshall Dual 50? Look in Hoffman's schematic library.
« Reply #2 on: December 13, 2019, 08:27:01 pm »
Sluckey the schematic i'm thinking about has a master vol for each channel
« Reply #3 on: December 13, 2019, 08:38:22 pm »
I seem to remember that. I think each channel also had it's own tone stack? I don't recall the particular thread though. But if it was on this forum you should be able to find it using the search button.
« Reply #4 on: December 15, 2019, 08:10:37 pm »
Yea it was two complete separate channels & it used relays (for & aft) for switching.
Offline VMS
« Reply #5 on: December 16, 2019, 03:33:50 am »
I found this thread but this one has shared tone stack so not sure if its the one you were looking:
http://el34world.com/Forum/index.php?topic=24600.0
« Reply #6 on: December 16, 2019, 05:39:34 am »
I simply modified Sluckey's Dual Marshall so each side has it's own tone stack.  On the attached SCH file there is a second page with the B+ rail, bias and PT.  I haven't built it but see no reason why it shouldn't work well.
Offline Auke Jolman
« Reply #7 on: December 16, 2019, 11:43:11 pm »
Hi All,
Looking at the schematic Tubenit shared with us, I wonder if it would be possible to switch between the 2 preamps right after the CF and eliminate V4?
With Regards,
Auke
« Reply #8 on: December 17, 2019, 12:27:45 pm »
Sluckey's dual plexi does that very thing.  However, the original poster was wanting two channels with each having a tone stack.
Offline Auke Jolman
« Reply #9 on: December 19, 2019, 10:29:26 am »
Hi Tubenit,
I think I messed up with what I wanted to ask. Therefore here's a schematic (quick and dirty) with my idea.
With Regards,
Auke
« Reply #10 on: December 19, 2019, 11:01:29 am »
The switch connected to the cathode will have big DC voltage on it.
Offline Auke Jolman
« Reply #11 on: December 19, 2019, 12:14:32 pm »
Thanks Sluckey, now it makes sense to not do it that way!
With Regards,
Auke
Offline VMS
« Reply #12 on: December 19, 2019, 01:20:23 pm »
Hi All,
That cf can drive multiple tone stacks, you can do it like this. Similar to JVM models.
https://el34world.com/charts/Schematics/files/Marshall/Marshall_jvm410_sch.pdf
« Reply #13 on: December 19, 2019, 01:33:03 pm »
concept - dual 2004/1987 circuits with separate preamps all the way to the LTPI.
from the LTPI to output stage it is essentially the same circuits for both models. UL output depicted.
a complex build for sure and not one for a novice builder. no layout provided - meld from the many existing layouts. respectfully, if you can't create your own layout, then probably something you shouldn't tackle.
