September 16, 2026, 08:34:47 pm
Hoffman Amps Forum image Author Topic: Reverb feeding back  (Read 4578 times)
Offline Fiat_cc
Reverb feeding back
« on: December 18, 2019, 05:24:02 am »
Hi all.
I built a Vox AC30 style circuit with the one tube reverb circuit that is somewhere on this forum.
I’ve used that circuit before and it worked great.
I’m this amp, it works a little too well, and it starts to feedback. Usually at a very ow frequency, although sometimes it’s higher. It’s in the same combo cabinet design I’ve used before, with a similar powered output section, but it definitely seems to be the tank feeding back. I’ve tried a different tank, playing with the orientation of the tank etc, but I haven’t stopped it yet. Lifting the tank and isolating it from the cab seems to work though.
Has anybody else had this issue and found a solid fix? Everything else about the amp is stellar.
Re: Reverb feeding back
« Reply #1 on: December 18, 2019, 05:50:22 am »
Is the reverb tank inside a bag to isolate it from the speaker?  I've also used outdoor carpet over a reverb tank successfully.
And I use rubber washers underneath the rim of the reverb tank. If you don't have rubber washers,  double stick tape will work reasonably well also.
Offline Fiat_cc
« Reply #2 on: December 18, 2019, 05:53:11 am »
I’ve tried in and out of the bag. I’ve got some rubber grommets I’ll try under the tank.
Offline Fiat_cc
« Reply #3 on: December 18, 2019, 11:52:58 pm »
I’ve tried a bunch of stuff now, and I can’t kill it. I’m wondering if it’s actually an oscillation in  the reverb section electronics rather than the tank itself. It’s hard to tell.
Once it starts though, the tank is vibrating viciously, but I’ve tried two tanks now with the same result. Even put a 12ay7 in to try and reduce the gain.
« Reply #4 on: December 19, 2019, 06:58:12 am »
While it's squealing unplug the send cable at the amp. Does it stop?
