September 16, 2026, 06:29:19 pm
Hoffman Amps Forum image Author Topic: Bias balance pot not functioning  (Read 5519 times)
Offline playindabluz
« on: December 18, 2019, 09:28:35 am »
I just finished a 20 watt JCM800 via Rob Robinette's design.  I cannot understand why the bias balance pot has no effect but the bias pot is functioning properly.  As an aside, I also cannot get the grid  reading below -47V.
« Last Edit: December 18, 2019, 09:44:40 am by playindabluz »
Re: Bias balance pot not functioning
« Reply #1 on: December 18, 2019, 09:33:41 am »
I don't see a bias balance pot on the layout you posted
« Reply #2 on: December 18, 2019, 09:39:07 am »
Sorry, my bad.   Here is the correct one.
« Reply #3 on: December 18, 2019, 10:08:00 am »
I also cannot get the bias reading below -47mV.
What is your procedure for measuring that?
« Reply #4 on: December 18, 2019, 10:10:58 am »
Sorry, I meant the grid voltage below -47V.  I check the bias reading at external test points off of pin 8.
« Reply #5 on: December 18, 2019, 10:23:37 am »
Increase the value of the 470Ω resistor feeding the bias diode. I'd start with 1K and go up/down in value until you have a suitable voltage.
I doubt the balance is going to have much range. I would check it by connecting the voltmeter between pins 5 of the two output tubes. You should be able to adjust the balance and see the meter reading swing positive and negative. The difference in voltage between pot extremes is the amount of swing you have. IE, if you get -4V with pot at max and get -4V with pot at min, then you have a swing of 8V. I'd set the reading to zero initially, then monitor the bias test points for final tweaking. If you connect a probe to each bias test point you can simply adjust the balance for 0mVDC.
« Reply #6 on: December 18, 2019, 01:11:59 pm »
Sluckey,
Thank you for the advice.   I was wondering about the value of the 470ohm resistor. You have confirmed my thoughts.
« Reply #7 on: December 20, 2019, 12:32:20 pm »
Sluckey,
sim hints at 470R > 2.2K to get -35V
