September 08, 2026, 01:50:38 pm
Hoffman Amps Forum image Author Topic: Signal tracing your amp with a multimeter.  (Read 9811 times)
Offline pompeiisneaks
  • Tube is as Tube does
    • Daviszone
« on: December 29, 2019, 01:31:32 pm »
Figured you guys might know this, but it can't hurt to share :)
Phil Davis
tUber Nerd =|D
Re: Signal tracing your amp with a multimeter.
« Reply #1 on: December 29, 2019, 02:23:54 pm »
In reference to the different voltage readings at the beginning of your video...
Why does the fluke show 150mV and the scope shows 400mV?
It's because the fluke is showing RMS voltage and the scope is showing peak to peak voltage. You need to know the difference and how to convert.
     Vpk = 1.414 x VRMS
     Vpk-to-pk = 2 x 1.414 x VRMS
     In your case, Vpk-to-pk = 2 x 1.414 x 150mVRMS = 424mVpk-to-pk
Maybe your scope is capable of displaying AC sine wave voltage amplitude in RMS value also???
    • Daviszone
« Reply #2 on: December 29, 2019, 08:13:10 pm »
     Vpk = 1.414 x VRMS
It probably is, I was just looking at the vernier divisions set at 50mV per division and could count 4 boxes so I knew it was 400mV peak to peak.  There are like multiple different measurements I can select, I may have to take a look at that,
Thanks!
~Phil
Phil Davis
tUber Nerd =|D
