September 16, 2026, 08:52:31 am
Hoffman Amps Forum image Author Topic: One channel AB763 No Trem (Circuit issue)  (Read 4486 times)
Offline ToneJunkie
  • Don't forget to play
« on: January 02, 2020, 12:03:46 am »
I found a mistake in a old amp I built and I have a question about the schematic I used.  This amp suffers from excessive gain and excessive bass.  I will post pics later but I was wondering if someone could help me with a schematic question.  In between the preamp and the coupling cap of the phase inverter I'm not sure how the circuit should be here.  Any help appreciated.
Offline glass54
Re: One channel AB763 No Trem (Circuit issue)
« Reply #1 on: January 02, 2020, 12:27:58 am »
Hi ToneJunkie,
I just used Hoffman's One Channel AB763 schematic and Turret board. Works well, in fact excellent.  :icon_biggrin:
In your case just remove the Tremolo section.
https://el34world.com/Hoffman/files/Hoffman_AB763_1.pdf
Kind regards
Mirek
« Last Edit: January 02, 2020, 12:30:59 am by glass54 »
"To measure is to know"
« Reply #2 on: January 02, 2020, 04:40:12 am »
To tame the gain you need to add a 47K resistor to ground at the point indicated in red. (It's R30 on the schematic linked by glass54). Also remove the 220K mixing resistor.
To tame the bass replace the four 22µF preamp cathode caps with 2.2µF or 4.7µF caps.
« Reply #3 on: January 02, 2020, 05:33:59 am »
I can't see why it does so (turnover frequency is way below bottom E), but the 47k ' pretend trem intensity control' resistor seems to calm the bottom end / thin the tone, a bit. So messing with the low end may not be necessary.
Offline Greg
« Reply #4 on: January 02, 2020, 07:55:13 am »
Just check (to be sure) the negative feedback dividing network to see if there is continuity... (If) the feedback loop is open in those type of amps, it might exactly sound like you have lots of gain and excessive bass...
Offline ToneJunkie
« Reply #5 on: January 02, 2020, 09:59:49 am »
Thanks guys!  So I have built several of these some with reverb and some without.  Why do we keep the mixing resistor when we do this circuit without reverb but remove the mixing resistor when we do this amp with reverb?
