September 15, 2026, 05:29:04 am
Hoffman Amps Forum image Author Topic: Center tapped primary?  (Read 6133 times)
Offline Captain chunkulus
« on: January 08, 2020, 12:32:55 pm »
Okay, so thinking about using this transformer for a tube preamp build. So, it has a groun on what looks like the primary side. Would I just connect that to the chassis since it is labeled  ground? Also, would that just become more or less the first star point for the power supply? Just trying to wrap my head around it. Thanks.
Offline Williamblake
Re: Center tapped primary?
« Reply #1 on: January 08, 2020, 12:47:30 pm »
The gnd on the primary is for safety and will only conduct if another winding is shorted to it so it will not really matter where you ground as long a you connect it well.
« Reply #2 on: January 08, 2020, 12:55:03 pm »
Great thanks!
« Reply #3 on: January 13, 2020, 07:58:44 pm »
Okay, just checking to see if one of you guys can give me some clarification on what I'm thinking. I don't want to wire this Transformer incorrectly. So what it looks like is for the primary to output u.s. voltage. it Goes black to Black red to red and then connect the black side to neutral, the red side to hot. Ground the purple wire. For the 150v dual secondary if I want 300v output I need to wire yellow to white. If I want 12.6 volts on the 2nd secondary wire I would wire green and brown. Next question  is by wiring the 6.3v taps for 12.6v, what happens to the 5v secondary? Will it still output 5v? Basically I'm running my 12ax7s on 12.6v and using 5v relays, that's why I'm asking. I hope these questions aren't stupid. Thanks guys. J
« Reply #4 on: January 13, 2020, 08:18:28 pm »
Why? And how many?
6V 2A will support six 12AX7 (12 triodes!), hum less than running 12VAC in the chassis, and leave the other winding free for other loads.
« Reply #5 on: January 13, 2020, 08:37:32 pm »
Why? And how many?
The original transformer only had a 24v tap so I ran the tubes on 12v dc using a voltage regulator.  It was dead quiet. So that's the way the heaters are wired now. I could rewire for 6.3v and maybe I will but it would be easier for me to just send the tubes 12v. So that begs the earlier question about the transformer wiring.
« Last Edit: January 13, 2020, 08:46:09 pm by Captain chunkulus »
« Reply #6 on: January 13, 2020, 11:49:10 pm »
5V tap will still be 5V in reference to the "0" tap.
If I were doing this I'd forget about the 5V tap and just put a FWB and big filter cap on the 12.6VAC. That will give about 17.8VDC unloaded. Send that 17.8v thru a 12v regulator for the filaments. Send that same 17.8v thru a 5v regulator for the relay.
« Reply #7 on: January 14, 2020, 08:09:29 am »
Will the amps be a problem  for the voltage regulator? Looks like the transformer puts out about 2 amps or current. I think the voltage regulator  is only rated for 1amp at 30v.
Also, would someone confirm the wiring for me. For 120v primary red to red black to Black, purple to ground. for 300v secondary, yellow to white and for the 12.6v Brown and green with the  blue going to ground?
« Last Edit: January 14, 2020, 08:22:09 am by Captain chunkulus »
« Reply #8 on: January 14, 2020, 10:49:18 am »
How many and what kind of tubes?
That's probably right. Takes only a few minutes to know for sure. Put it on the bench, temporarily make those connections, power up, and make measurements. Watch for smoke!   :icon_biggrin:
