September 14, 2026, 11:20:51 pm
Hoffman Amps Forum image Author Topic: Crate Vintage Club 50 Redplating  (Read 8355 times)
Offline judgeamps
« on: January 18, 2020, 05:02:59 pm »
Hey all, long time lurker.
A customer brought me a Crate Vintage Club 50 that wasn't putting out a signal. I found the 1/2 amp fuse coming from the standby switch was blown, the standby switch itself wasn't operating properly, and a few filter caps were visibly bulging. Replaced all of those things and everything looked good. After testing for about 5 minutes, all 4 power tubes red plate.
Schematic attached.
Here's what I've found:
Tried new tubes, same issue.
All Test Points are pretty much spot on.
I suspected a bad bias, but that section seems pretty good. I'm getting -15.6 V on pin 2 of the EL84's.
I replaced R52 because it looked questionable. (crumbling)
I tested the coupling caps (c27 and C28) coming off of pin 2 and they also test out fine.
R58 going into the standby switch differs from the schematic. It's 220k (schematic calls for 150k and I don't have that value on hand) Looks like it could have been replaced at some point in it's life. Would that cause red plating?
I'm not seeing any cold solder joints
Re: Crate Vintage Club 50 Redplating
« Reply #1 on: January 18, 2020, 05:14:50 pm »
no
Offline judgeamps
« Reply #2 on: January 18, 2020, 05:23:44 pm »
Thanks, sluckey. I was 99.9% certain, but wanted to make sure I wasn't having a "brain fart."
I also realized I swapped the standby connections J31 and J37 when re-attaching.
Offline judgeamps
« Reply #3 on: January 18, 2020, 08:34:15 pm »
Update:
After about 5 minutes, voltage at TP 17 starts to increase (moves from -15.5 to -15) and starts red-plating.
Out of curiosity what's the point of C54? 470pf 500v ceramic cap.
Thanks in advance.
« Reply #4 on: January 18, 2020, 09:21:37 pm »
It does just the opposite of C40.
« Reply #5 on: January 19, 2020, 08:12:01 am »
I would pull the output tubes and monitor TP17. If the voltage still changes it means that the coupling caps (C27 and/or C28) may be leaking. Or there is an issue with the bias supply, most likely C49.
Offline judgeamps
« Reply #6 on: January 19, 2020, 08:37:10 am »
I thought the same thing and replaced all 3 of those components this morning. Same problem. Voltage at TP17 doesn't seem to budge when the power tubes are pulled.
Thanks again.
« Last Edit: January 19, 2020, 12:04:12 pm by judgeamps »
« Reply #7 on: January 19, 2020, 09:00:37 am »
are the tube sockets mounted on the PCB?
have you looked at the underside of the PCB, I've found interesting things there before
Offline judgeamps
« Reply #8 on: January 19, 2020, 09:06:13 am »
Oh yea, I've been spending a lot of time under this darn PCB. Haha. Re-soldered pretty much everything.
Offline judgeamps
« Reply #9 on: January 19, 2020, 12:03:57 pm »
Seems like one of those replacements did the trick and I just didn't realize it because this amp runs so hot. I let it idle for about an hour and TP17 is always around -15.54 which is .06 off of the chart on the schematic, but no red-plating.
