September 17, 2026, 02:07:41 am
Hoffman Amps Forum image Author Topic: Deluxe reverb effects loop  (Read 6414 times)
Offline phsyconoodler
« on: January 28, 2020, 08:41:52 pm »
I'm building a one channel deluxe reverb and was wondering if it will work inserted where the PI 220k insert point is normally?
  I can add a master volume if necessary.
Just a simple passive loop
Re: Deluxe reverb effects loop
« Reply #1 on: January 28, 2020, 11:51:00 pm »
That'll work.
Offline d95err
« Reply #2 on: January 29, 2020, 01:04:15 am »
Passive loop? You at least need a recovery stage to bring the signal back up again.
An alternative is to put the loop in parallell with (or replace) the reverb circuit.
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #3 on: January 29, 2020, 11:22:12 pm »
As d95err noted, the signal level will be diminished when an effects device is inserted at that point and you won't be able to get the full wattage out of your amp, but lots of people do that.  If you're not worried about the possibility that you might not have enough wattage to get the police over, then go for it.
Offline 2deaf
« Reply #4 on: January 29, 2020, 11:31:46 pm »
Here are a couple of ideas for combining the reverb circuit with an effects loop.  I haven't tried either one, but they calc out pretty good on paper.  I'm not real sure there is any particular advantage over just putting the effects in front of an amp like this.  I guess it could drive a line-level device with the loop.
« Last Edit: January 29, 2020, 11:41:58 pm by 2deaf »
