September 17, 2026, 04:23:36 am
Hoffman Amps Forum image Author Topic: Which filter layout to use for AB763?  (Read 5490 times)
Offline markmalin
  • Malin Sweet Loraine
    • Malin Amplification
« on: January 29, 2020, 10:38:40 am »
Hi All,
I'm building a one-off for myself to use, a single channel AB763 with reverb and no tremolo and a pair of 6L6 output tubes.  Regarding the filter board in the doghouse, I was reading on Rob's page about the 2 board configurations in the AB763 doghouse and I'm assuming most people are familiar so bear with me.  Both configurations use 5 filter caps, the Deluxe Reverb has the first 2 caps in parallel and uses 2 10K dropping resistors.  All other AB763's use the second configuration where the first 2 caps are larger value (80uf) in series (with 220k resistors in parallel with each cap), then use I think 1K and 4.7K dropping resistors.
My questions:
- why did Fender use two different configurations?
- which would be recommended for my amp?  (AB763, one channel, 6L6's, non tremolo)
Humbly,
Mark
"... there are Flying V's and then there are the ones shaped like peanuts..."  - my son at age 9
Re: Which filter layout to use for AB763?
« Reply #1 on: January 29, 2020, 11:25:09 am »
Because they have a low power 6V6 version and several higher power 6L6 versions. The voltage requirements for each are different.
Why would you even consider using the DR power supply in a 6L6 amp?
Offline markmalin
« Reply #2 on: January 29, 2020, 11:36:31 am »
Thanks, Slukey.
What was confusing me was in the Hoffman AB763 1 Channel layout diagram it shows the caps laid out like the DR version, and in the BOM he has 5 22uf/500v caps.  I realize there are differences between the 6L6 and 6V6 AB763's parts list, and the notes speak to that, but I didn't find any discussion on the power supply section being different.  Maybe I missed something.  I had ordered off this BOM so I have the 5 22uf/500's on hand, so I'll go ahead and order two larger caps
https://el34world.com/Hoffman/files/Hoffman_AB763_1.pdf
Cheers,
Mark
« Reply #3 on: January 29, 2020, 12:02:46 pm »
If you look at the two channel docs you'll see the differences between versions annotated. Still no reason why. My guess is that the 6L6 versions require higher B+ for the small tubes in order to get a higher signal to drive the 6L6s to their screaming potential.  :icon_biggrin:
You've probably seen this but look again, paying attention to the "parts in blue". You still need the BOM pdf to know what the actual values are...
     https://el34world.com/Hoffman/files/Hoffman_AB763_2.pdf
Offline markmalin
« Reply #4 on: January 29, 2020, 12:37:57 pm »
Ahah!  Thanks - dang, I don't know how I missed that link.  That lays it all out.  I guess I was just looking in the 1 channel doc.
Mark
