September 15, 2026, 11:08:11 am
Hoffman Amps Forum image Author Topic: 5e3  (Read 6604 times)
Offline Rockranger
5e3
« on: February 09, 2020, 02:12:48 pm »
https://el34world.com/Hoffman/files/Hoffman_5E3.pdf
Looking to add a nfb switch to the Hoffman 5e3, if anyone has any info on this it would be appreciated. Thanks
Re: 5e3
« Reply #1 on: February 09, 2020, 03:35:37 pm »
there's no nfb for a switch to be added to.
surf up more fender schemo's to find how they did use nfb.
fwiw, the schematic attached has NOT been built/tested, but was stolen um borrowed from the other attached schematic
Re: 5e3
« Reply #2 on: February 09, 2020, 07:03:32 pm »
see items circled in RED - you need to fiddle with the value of the 1500Ω NFB resistor as shown: it can be anywhere from 820Ω to 5KΩ or more - i chose 1500Ω because it made the paint chop up easier, but is also a good value to start with.
IF you add NFB loop you may need to swap the OT primary leads if the amp squeals on initial power-up. after wiring in, use SW to check - e.g. power up with SW open - if it squeals when SW is closed, then swap OT primary leads.
« Last Edit: February 10, 2020, 02:33:59 pm by DummyLoad »
Offline isaac_teller
Offline 2deaf
  • Now too deaf for 100 watts
Re: 5e3
« Reply #4 on: February 10, 2020, 02:25:28 pm »
I like Dummyload's version better than Robrob's because Dummyload's has about twice the open-loop gain.  If the unbypassed gain stage has 6dB less gain than the bypassed gain stage and the closed-loop gain is -6dB in both cases, then Dummyload's version takes a 6dB hit with NFB and Robrob's takes a 12dB hit.
Re: 5e3
« Reply #5 on: February 10, 2020, 11:04:41 pm »
Rob's linearizes the 12AX7. This stage dominates the 2nd harmonic of the otherwise push-pull amp.
Different, not better/worse.
Offline 2deaf
Re: 5e3
« Reply #6 on: February 11, 2020, 08:47:13 am »
Allow me to re-phrase my statement to make it a bit more difficult to quote out of context.  "I, and I alone, would prefer to use Dummyload's version rather than Robrob's . . . "
Re: 5e3
« Reply #7 on: February 11, 2020, 09:53:25 am »
I know who "I" is. But who is "I alone"?   :dontknow:
Re: 5e3
« Reply #8 on: February 11, 2020, 10:47:47 am »
think it's lyric from a '90s grunge band; "I alone love you I alone......"   :icon_biggrin:
Offline 2deaf
Re: 5e3
« Reply #9 on: February 11, 2020, 11:11:28 am »
You got it.  I learnt English from a car radio.
Re: 5e3
« Reply #10 on: February 11, 2020, 11:49:01 am »
 :l2:
Yup, NO spelling tests !!!
