September 17, 2026, 02:07:24 am
Hoffman Amps Forum image Author Topic: The Rob Robinette JCM 800/22 6V6  (Read 11411 times)
Offline ToneQwest
« on: February 17, 2020, 09:07:26 am »
Does anyone here know how to add a passive FX loop to the RR JCM-800/22 watt circuit?
There is s very simple and effective mod that Rob Robinette posted for the much modded 40watt 5E3.
Can this additional feature be easily added to the 22 watt JCM800?
I emailed Rob, but he doesn't seem to be answering emails as of late. Everyone is busy these days.
Re: The Rob Robinette JCM 800/22 6V6
« Reply #1 on: February 17, 2020, 10:10:51 am »
fwiw
I've put this FX in 2 amps, works great, no hard thinking required  :icon_biggrin:
« Reply #2 on: February 17, 2020, 10:45:36 am »
Just install the send and return jacks between the treble wiper and the .022 coupling cap (input to LTP PI). Kinda like this...
     http://sluckeyamps.com/lightning/matchless_lightning.pdf
...or this...
     http://sluckeyamps.com/november/november.pdf
Offline d95err
« Reply #3 on: February 18, 2020, 03:00:32 am »
Passive fx loop is kind of useless in this type of amp, IMHO.   Either, the send signal will be so hot it will distort any effect in the loop (or even damage it), or you have to pad the signal way down, leaving the amp unable to reach full power.
At minimum, some kind of active return stage is  necessary for a working loop.
« Reply #4 on: February 18, 2020, 06:03:31 am »
I think there are advantages of an active FX and currently, my amps only have an active FX.  However, I have run the following pedals in a passive FX (with both Dumble inspired and Marshall inspired topologies) and I thought this worked out  just fine:
Wampler Faux Echo,  Boss Digital Delay, Digitech reverb,  Moen Pretty Dolly Delay, MXR Carbon Copy & old Ibanez Flanger.
I've also read on more then one occasion that someone preferred the passive FX loop on their Dumble amp or Dumble clone instead of using the Dumbelator active FX loop.
Offline ToneQwest
« Reply #5 on: February 18, 2020, 01:18:14 pm »
Rob Robinette replied to my email suggested this:
"Yes, we can insert a passive FX loop.
I haven't tried it but I would put
the loop between the cold clipper's output coupling cap (.022uF) and the
470k Attenuator resistor. Rob"
The only candidate 470K resistor on the JCM800/22 diagram is the 470K treble bleed that is wired in parallel with a 470pF capacitor.
Could this be the "attenuator" Rob is referencing?
« Reply #6 on: February 18, 2020, 01:38:01 pm »
Yes, that's the one.
« Reply #7 on: February 18, 2020, 02:16:42 pm »
I would go with Sluckey's idea in reply #2 instead of Rob's suggestion.
Offline ToneQwest
« Reply #8 on: February 18, 2020, 02:23:11 pm »
Tubenit, with all due respect to you and everyone on the forum helping me on this; what is your preference based on? I am purely curious.
« Reply #9 on: February 18, 2020, 02:50:45 pm »
My suggestion is based on a proven circuit. I bet tubenit's preference is based on the same. I doubt Rob or anyone else has actually tried Rob's suggestion, which may work way better, but who can say. It's very easy to try it as Rob suggested and then try it as I suggested. Then you'll be the passive loop in the RR JCM-800/22 watt circuit expert.  :wink:
Offline ToneQwest
« Reply #10 on: February 18, 2020, 03:20:08 pm »
By the way, what are the values for the metal foil resistors on the Pre-Amp Out and between top and sweeper lug?
Offline ToneQwest
« Reply #11 on: February 18, 2020, 03:52:44 pm »
100K .5 watt & 220K .5 watt.
Thank you all!
« Last Edit: February 18, 2020, 04:01:51 pm by ToneQwest »
« Reply #12 on: February 18, 2020, 03:53:19 pm »
Talking about my Lightning? Color code is on the layout. Written values are on the schematic. You don't need either of these for rob's amp.
Offline ToneQwest
« Reply #13 on: February 18, 2020, 04:02:36 pm »
Yes, got it! Thanks again!
« Reply #14 on: February 18, 2020, 08:22:11 pm »
And the reason that is my preference is I have tried a passive effects loop earlier in the signal path and did NOT like it as well. I am usually using delay.  I don't want the delay to have gain added to it, so further down the signal path is my preference.
Sluckey's suggestion is a proven circuit and I've used it successfully numerous times.
Offline ToneQwest
« Reply #15 on: February 19, 2020, 10:08:32 pm »
Thank you for the sound reasoning! That is what I will do, as the effects I have in mind are modulation and delay.
Offline tbguitar55
« Reply #16 on: July 12, 2023, 07:26:44 pm »
Based on the original post, I reached out to Mr. Sluckey for some help with my Robinette 800Micro. Mine is the second one shown on the website, and I was lucky enough to buy it from the original owner/builder. One of the best amp buys yet! Mr. Sluckey helped me with my questions, and educated me to the 'magic' that I never really understood, until now. As a result of his generosity, I now have an improved amp with a fully functional FX loop (for my needs!), and have now taken the next step to add an FX loop to my Dabeck 18W next. Preliminary results were fruitful - awaiting my Swithcraft shorting jacks now to finish off both amps properly! Thank you so much for the info here, and to the help received from Mr. Sluckey!
https://hearditontheweb.com/gear
« Last Edit: July 12, 2023, 10:03:58 pm by tbguitar55 »
Offline ToneQwest
« Reply #17 on: November 13, 2023, 05:53:34 pm »
Lastly! Are there Hammond PT and OT alternatives to the Allen Amps PT & OT listed on Rob Robinette's website for the JCM 800 6V6 22 watt amplifier?
