September 16, 2026, 10:35:42 pm
Hoffman Amps Forum image Author Topic: HiFi output tranny with screen windings  (Read 4199 times)
Offline shaun
« on: February 19, 2020, 03:19:24 pm »
I have an old output tranny from a Bonnet Box record player (circa 1960). The amp was akin to an AC30 (4 * EL84s and an EF86 pre, 12ax7 PI).
It has two output taps, but it also has four primary taps, or at least it seems that way. Two leads went to the EL84 plates, and two went to the 9 pins - the tubes were paired. So it seems the design used AC from the transformer to balance the screen grid to the plates. I just wondered if anyone knew anything about how these worked, as I'd like to try the transformer in a build sometime.
Cheers.
With gratitude.
Re: HiFi output tranny with screen windings
« Reply #1 on: February 19, 2020, 03:26:17 pm »
Search for ultra linear (UL). Plenty of info about UL. You can also use that OT in a standard PP circuit by just taping off the screen taps and connecting the screens as usual.
Offline shaun
« Reply #2 on: February 19, 2020, 03:39:23 pm »
Thanks Sluckey. I'll do the research.
With gratitude.
