September 17, 2026, 08:24:37 pm
Hoffman Amps Forum image Author Topic: 2204 using Hammond 290GX PT  (Read 4877 times)
Offline Mehfuzhoss
« on: February 21, 2020, 12:05:36 pm »
Hello El34world,
On the secondary side of the PT there are two black wire (well one is glossy black, one is matt black). my question is, how can i figure out the black wire that has 3.15v? the other black wire will connect to ground. please help. spec sheet is attached.
Offline SnickSound
Re: 2204 using Hammond 290GX PT
« Reply #1 on: February 21, 2020, 12:18:27 pm »
I believe the 3.15V one will be a thicker gauge. Are there differences in wire thickness?
Been a while since I built mine, I'd have to open it up to see
« Reply #2 on: February 21, 2020, 12:25:20 pm »
Hello El34world,
Connect one probe of your ohmmeter to the orange wire. Now touch the other meter probe to a black wire. If you have a very low resistance (close to zero ohms) then you got the right wire. Twist it together with the orange. If no, grab another black wire.
Offline Mehfuzhoss
« Reply #3 on: February 21, 2020, 02:18:53 pm »
yes different gauges. the shiny black is thicker, must be this one the 3.5v
« Reply #4 on: February 21, 2020, 02:22:36 pm »
Do what I suggested and be sure.
Offline Mehfuzhoss
« Reply #5 on: February 23, 2020, 08:43:30 pm »
the thicker black wire shows lower resistance. i used that one with orange for heater wire.
