September 17, 2026, 11:53:39 am
Hoffman Amps Forum image Author Topic: plexi 50 modification question.  (Read 4473 times)
Offline Curranm
« on: February 25, 2020, 03:29:02 pm »
I am going to build a hoffman 50 with the hot switch on a relay. At the 470K/470K voltage divider going into the next tube stage after the relay I w9ould like to put in another Volume/gain control. So I was going to replace the 470K to ground with a 500kA or 1MA pot. is the right spot for something like that? Everything else about the schematic will stay the same. just curious! thanks in advance for your help!
Re: plexi 50 modification question.
« Reply #1 on: February 25, 2020, 04:17:24 pm »
Sounds like a good plan.
« Reply #2 on: February 25, 2020, 05:10:17 pm »
I attached Dougs version, He re-purposes the 2nd input so there isn't any 470k voltage divider.
Are you doing something different than His intent?
« Reply #3 on: February 25, 2020, 05:55:14 pm »
 :think1:
missed 12b
Offline Curranm
« Reply #4 on: February 27, 2020, 08:50:16 am »
I am not really trying to break away from the 50 hotswitch plexi, BUT I have built one of these before AND I want to make the switched in stage a bit more fun and controllable with the added gain control. that is really where my noodle is at.
« Reply #5 on: February 27, 2020, 10:03:25 am »
Just replace R12b with a 500K pot. One leg to ground, one leg to C3, and the wiper to the switch.
