September 17, 2026, 02:04:43 pm
Hoffman Amps Forum image Author Topic: Marshall 1987: only 2 inputs (one high, one low) wiring  (Read 4314 times)
Offline pi-amp
« on: February 27, 2020, 08:17:22 am »
Hello!
i'm building a 1987 clone and i only have room for 2 inputs.
what i want :  bright and normal 2 channels permanently bridged, and one high and low input.
Plugin in the high input feeds the 2 channels and i can blend them with the 2 volumes. Same for low input.
Now i'm wondering how to wire the thing.
I tried with the normal inputs wired normaly with the 2 68k going to one grid of the triode (say pin2)
And then the other grid simply connected to the first grid (pin 2 and pin 7 tied together)
It works, but i wonder if it's electricaly the same as if the triodes add their own grid stoppers ?
Offline turtle441
Re: Marshall 1987: only 2 inputs (one high, one low) wiring
« Reply #1 on: February 27, 2020, 09:00:55 am »
That'll work.  The Plexi SE uses a similar set-up with a 33k resistor instead and works great as well.  For those math-oriented types, see Merlin Blencowe's write-up.  It appears there's a range of resistors you can consider based on noise issues, etc.
http://www.valvewizard.co.uk/gridstopper.html
Offline pi-amp
« Reply #2 on: February 27, 2020, 10:00:31 am »
thanks !
