September 15, 2026, 02:12:02 am
Hoffman Amps Forum image Author Topic: extra tubes on the 6.3VAC circuit  (Read 9454 times)
Offline AxeAmpTN
  • Shop small; support local music.
    • Axe & Amp
« on: February 27, 2020, 04:29:06 pm »
This is probably going to sound very strange, but I have a customer with a custom build request that is essentially a Vibrochamp, but with lots of extra tubes just for looks.  He wants the heating elements to light up, but is NOT interested in using them for the amplifier.
So my question is this:  if I add about 6 more tubes on the 6.3VAC line from a Champ PT, will it put added strain on the actual amplifier circuit?  Or would I be better off adding an extra 6.3V tranny just for that?
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
Re: extra tubes on the 6.3VAC circuit
« Reply #1 on: February 27, 2020, 04:52:48 pm »
you'll be adding ~ 2A ( .3*6)
seems a champ PT might feel the strain.
an alterativealternative  :think1: I did, drilled out the socket to accept an LED which shined up into the tube, used it as my power on light  :icon_biggrin:
Offline AxeAmpTN
    • Axe & Amp
« Reply #2 on: February 27, 2020, 05:12:16 pm »
Thanks, shooter.  I have considered the LED idea and may yet propose that to him.  It will be more easily visible anyway.
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
« Reply #3 on: February 27, 2020, 05:39:32 pm »
there's a bunch cheapish of C-made kits that can "pulse to the music", think disco tubes  :laugh:
« Reply #4 on: February 27, 2020, 06:00:16 pm »
+1 for Shooter Led idea
« Reply #5 on: February 27, 2020, 11:58:21 pm »
Six 19EZ8 across the 110V line. Cheaper than one more 12AX7.
https://vacuumtubesinc.com/index.php/vacuum-tubes/19ez8.html
« Reply #6 on: February 28, 2020, 02:27:47 am »
Ciao PRR
The idea is nice, but this way the 110V line isn't going around the chassis without a galvanic protection ?
EDIT:
May be a set of 1R5 tubes (6 or 7 tubes) connected in series to the 6.3V winding ?
1R5 heater = 1.4V @ 0.05A (the load is minimal as they will be in series)
http://www.r-type.org/pdfs/1r5-1.pdf
10 tubes at 10.08€
https://www.esco.it/product_info.php?products_id=1279
« Last Edit: February 28, 2020, 04:32:52 am by kagliostro »
Offline nandrewjackson
« Reply #7 on: February 28, 2020, 04:27:40 am »
I would NOT risk burning up a power xformer for that.
LEDs yeah
PRRs idea  yeah.
Offline AxeAmpTN
    • Axe & Amp
« Reply #8 on: February 28, 2020, 10:15:01 am »
Ciao PRR
EDIT:
10 tubes at 10.08€
Fascinating ideas, kagliostro and PRR!  I'll explore that a little.  Are either of those tubes' heaters brighter than what you'd find in an average 12AX7?
At the moment, the LED's are probably getting first consideration as there will be the greatest opportunity for interesting lights at a cost effective price point.
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
« Reply #9 on: February 28, 2020, 10:33:46 am »
the 6 EXTRA tubes will NOT impress a good player, the LEDS might get $2 in the tip jar  :icon_biggrin:
always consider your audience when building  :laugh:
« Reply #10 on: February 28, 2020, 10:59:00 am »
The battery (1.4V 0.050A) filament tubes' glow is hard to see.
Offline AxeAmpTN
    • Axe & Amp
« Reply #11 on: February 28, 2020, 11:25:34 am »
You're absolutely right, shooter.  But this guy just wants a nice showpiece for home use.  It's actually an old tube-powered EKG machine that he wants turned into a guitar amp.  Since it has a display window for the stylus and paper, he thought it would be cool to see a bunch of glowing tubes inside.  Unfortunately, with limited space and wattage, it's better to have some tubes just for looks (and it already came with 8 or so) and to put in a new circuit for the amp than to try to put the amp tubes where they'll be seen.
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
« Reply #12 on: February 28, 2020, 11:47:00 am »
Not many little low current tubes make enough light to be impressive to anyone. You need big bottles to get excited.
However, gas regulators like 0A2, 0B3, OBwan, etc. are really impressive and they don't require any filament supply. Just a series resistor to B+ and you get a nice glow. Should be able to find them pretty cheap too
« Reply #13 on: March 01, 2020, 09:05:40 am »
 :BangHead:
..... gas regulators like 0A2, 0B3, OBwan, etc. are really impressive and they don't require any filament supply.
 :thumbsup:
.... it already came with 8 or so
if you mean tubes (8 tubes) aren't that enough ?
and, other question
if the PT is to be used for a champ (0.3A for preamp + 0.45A for power tube = total 0.75A), assuming those 8 tubes have a consumption of 0.3A each one, you have a total disposable current of 8 x 0.3A = 2.4A
if you subtractminus the consumption of a champ (0.75A) from the disposable current (2.4A) leave you with 1.65A of available current, with that you can feed 5 x 0.3A heater tubes or, a big bottle ..... 6L6 or 807 (I like the 807 aspect)
Can this satisfy the request ?
« Reply #14 on: March 01, 2020, 07:21:27 pm »
impress the girls  :icon_biggrin:  4E27/5-125B locate a used/dead one ebay, buy it for the filament - filament supply is 5V @ 7.5A.
use a LED string lites for a faux plate lead. the filament makes a nice night lite.
Offline davidwpack
    • My music on reverbnation
« Reply #15 on: March 02, 2020, 02:51:21 pm »
I did a tube night light with LEDs. Wired them a put them in a pedal box.
« Reply #16 on: March 03, 2020, 06:00:57 am »
Offline AxeAmpTN
    • Axe & Amp
« Reply #17 on: March 04, 2020, 02:16:38 pm »
I apologize for not getting back to this sooner.  Thanks for the input and ideas, everyone!
and, other question
Franco, the tubes that came in the unit were:
4x 6AQ5
3x 12AX7 (which will probably get reused)
1x 5651
1x 6AS5
Your math makes good sense and may come in handy to get something going here.  But I'm also digging the suggestions for the 0A2, 4E27, and 807 applications...unfortunatly, I'm not very familiar with those.  I was just browsing data sheets about them.
So new question:  what might be the best way to incorporate something like an 0A2 in something like this?  It seems like it will have an impact on the amp circuit, but maybe that's what we want here???
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
« Reply #18 on: March 04, 2020, 04:10:46 pm »
You already have one of the most popular gas regulator tubes... 5651. Just connect one end of a resistor to B+, the other end of the resistor to the plate, and the cathode to ground. I'd start with a 100K and adjust up/down for a pleasing glow. Do the same for any of the others such as 0A2.
« Reply #19 on: March 04, 2020, 04:48:53 pm »
as the transformer can handle the current
I will probably extend the reuse also to the 4 x 6AQ5 tubes (after all they are 6V6 in a small envelope)
« Reply #20 on: March 04, 2020, 07:02:52 pm »
Just for you... I rigged up a 5651 and 220K/.5W resistor and connected it to a 300V B+ node in an amp on my bench. Works very well on 425V also. Maybe this is a visual your friend would like. Only about 1mA current. If you decide to do something like this I suggest creating a separate B+ node that's fed directly from the reservoir cap.
« Reply #21 on: March 05, 2020, 02:29:29 am »
+1 for Sluckey's separate node to feed the gas tube
Offline AxeAmpTN
    • Axe & Amp
« Reply #22 on: March 05, 2020, 10:45:02 am »
Sluckey, that's awesome!  That was one tube I didn't really know about!
Can you define "reservoir cap" for me?  That's not a term I recognize from my usual tube amp work.
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
« Reply #23 on: March 05, 2020, 10:56:12 am »
filter cap help?   used in PS "chain"
« Reply #24 on: March 05, 2020, 11:18:46 am »
First cap on PS in this case (I suppose)
« Reply #25 on: March 05, 2020, 11:25:25 am »
Reservoir cap is a term I never used before hanging out on guitar amp forums. It is a term that lots of guitar heads use to identify the first filter cap connected to the rectifier. I personally consider every filter cap as a "reservoir" cap. Anyhow just to be clear I'm referring to the first cap connected to the rectifier, also called Node A, plate supply, etc. My suggestion to make a separate node that is connected to the first filter cap is so your downstream voltages don't change with the additional load of the gas tubes.
Example, the voltage on your first filter cap is 425V. I would connect one end of a 5K 10W resistor to the first filter cap and connect the other end to a new 22µF cap to make a separate filter node. Now use this node to supply as many 5651s as you want (be reasonable here). Don't forget to use a separate series resistor for each tube, ie, four tubes, four resistors.
Offline AxeAmpTN
    • Axe & Amp
« Reply #26 on: March 05, 2020, 12:46:29 pm »
Thank you! That helps!
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
Offline ALBATROS1234
« Reply #27 on: March 09, 2020, 05:01:12 pm »
why not get a $10 filament xfrmr i have gotten 6.3v @ 2amp type for that several times then just parallel the primary with your other transformer primary.
Offline AxeAmpTN
    • Axe & Amp
« Reply #28 on: May 22, 2020, 11:41:04 am »
Hey y'all...I really appreciate everyone's input on this.  I just wanted to follow up to show off a few photos of how it came out. Thanks again!
FB: axe.amp
IG: axe.n.amp
Tw: axeamp
