September 08, 2026, 06:25:51 pm
Hoffman Amps Forum image Author Topic: Drilling through eyelet boards  (Read 5223 times)
Offline lljsullins
« on: March 21, 2020, 12:56:39 pm »
So I'm needing to mount my eyelet board to my amp chassis, but there are no holes. I need to drill some into the boards! Is there any specific thing I should do/lookout for when I do this?
Thanks all.
Re: Drilling through eyelet boards
« Reply #1 on: March 21, 2020, 01:07:30 pm »
Mark and counter punch the hole locations. Then drill. Drill press preferred but hand drill works fine if steady hand. Best to do this before loading components.
« Last Edit: March 21, 2020, 02:11:22 pm by sluckey »
« Reply #2 on: March 21, 2020, 01:45:27 pm »
+1
I'll typically drill the board, mount standoffs, then dab paint on the "chassis side" of the standoff.  set board/standoff in place, remove, now I have "drill guides" on the chassis
« Reply #3 on: March 21, 2020, 02:29:01 pm »
On a different job, I clamped board and box together, drilled both at once, so the holes WOULD line up.
Yes, just drill it in the right place. Wood-bits work. Fiberglass board wears bits faster than wood but for 4-6 holes it isn't a problem; when you get a contract for thousands of amplifiers you can buy better drill bits.
« Reply #4 on: March 22, 2020, 07:59:16 am »
Thanks all.
Read this
https://el34world.com/Hoffman/instructions.htm
Offline Soulfetish
« Reply #5 on: March 22, 2020, 11:24:42 pm »
Also, FR4 (or any glass-epoxy) board is extremely abrasive and will destroy HSS or cobalt drills with a quickness that will hurt your feelings.
If you only have a couple of holes and don't mind dulling some drills, then ain't no thing to get through a job. But, if you think you might want to build a couple of amps or projects, then investing in a couple of carbide stub (machine screw) drills is a good investment.
I use a Melin #31 135˚ carbide drill for a hole diameter designed to fit M3 fasteners
