September 14, 2026, 11:16:08 am
Hoffman Amps Forum image Author Topic: Magnatone Vibrato/Reverb build Project  (Read 382711 times)
Re: Magnatone Vibrato/Reverb build Project
« Reply #150 on: May 05, 2020, 03:37:17 pm »
DON'T TAKE IT OUT!
Offline wsscott
« Reply #151 on: May 05, 2020, 03:40:16 pm »
Believe me I wasn't going to do that!  But I was curious about what the effect would be on the circuit.  Seems like the DCV at B would be much too high and it would need to be reduced somehow.
« Reply #152 on: May 05, 2020, 04:10:41 pm »
Filter caps don't drop voltage. They just smooth it. Go read that power supply link again.
There is a good chance that you may have to juggle the resistor value between Node A and Node B. The missing load of the PA will cause all the voltages to rise. But that's assuming you will use the exact same PT as in the orig M10A. I seriously doubt that! It's unlikely but the PT you choose may already give you 'perfect' voltages. This is not something to worry about but plan to change a resistor (or two) in the PS rail. IOW, make sure your layout will provide easy access to the power supply resistors.
« Reply #153 on: May 05, 2020, 04:20:49 pm »
fwiw;
this is one of the better finds for WHY answers, It'll make studying for the boards seem easy  :icon_biggrin:
http://www.aikenamps.com/index.php/white-papers
Offline wsscott
« Reply #154 on: May 05, 2020, 04:28:41 pm »
Thanks again to both of you.  Stephen
Offline wsscott
« Reply #155 on: May 06, 2020, 08:06:52 am »
For those sections of the layout where there are several components in a row leading to ground, such as in the Vibrato speed/intensity section, is it ok to jumper them together as in a daisy-chain and then lead off to ground from the last one in the chain--as opposed to connecting each one to GND separately?
« Reply #156 on: May 06, 2020, 08:08:41 am »
yes
Offline wsscott
« Reply #157 on: May 06, 2020, 09:12:24 am »
Sluckey, in your Reply #87 you attached this photo http://sluckeyamps.com/lil_maggie/m_big.jpg .  Do you have a photo of the underside of the board so I can see how the hookup wiring looks?  Or another build that you did?  My DIY Layout drawing has a lot of wires coming out of it and it just looks messy.  I'm trying to neaten it up, etc.  Thanks.
« Reply #158 on: May 06, 2020, 10:31:43 am »
you have a lot of tubes, so more wires.
look at one of Dougs  turret boards for an AB763, something like twin reverb layout.
this is a simple 3 tube, the blue wires are jumpers, the layout keeps parts for each tube "close" to the tube.  When I build it, the jumpers will be on top, as a service guy, I hate the extra work of "looking" under the board  :icon_biggrin:
Offline wsscott
« Reply #159 on: May 06, 2020, 11:10:59 am »
I notice that in the layouts that both of you have provided, in most instances you've got the components running vertical and parallel to each other, and that you connect them where needed with horizontal jumper wire.  But there are times when no jumper is used, and the components are connected at an angle to each other at the turret, sometimes like a V junction.  Is there any reason why you don't use the jumpers sometimes and just connect the components directly at the turret and lose the parallel scheme?  Is this just an appearance sort of thing?
« Reply #160 on: May 06, 2020, 11:12:17 am »
There are two pics on this link that deal with my underboard jumpers. I highly recommend doing them this way. Look closely at the way the jumper is inserted thru the bottom of the turret and hooked over the top of the turret. My jumpers will not accidentally fall out when soldering other components. Jumper wires are 24AWG solid tinned copper. I stripped insulation from 22AWG teflon wire to slip over the jumpers when they need to be insulated.
     http://sluckeyamps.com/VAC15/ac15.htm
« Reply #161 on: May 06, 2020, 11:15:10 am »
It's just my style. I prefer parallel components but some times you just need a "V" or "birds foot" for neatness or to be compact.
Offline wsscott
« Reply #162 on: May 06, 2020, 11:21:44 am »
Great photos from your build.  Its really helpful to see how it was assembled in stages.
Offline wsscott
« Reply #163 on: May 06, 2020, 04:13:58 pm »
Well I finished this layout, and am attaching 2 files and ask you to take a look. The main issue I'd like some input on is whether the layout looks like it will hold the components ok or if things are too close together.  I've attached the DIY layout and the Hoffman Turret analyzed layout for a turret board. I printed out the Turret board to scale and everything fits, I just don't know if the turrets are too close together.  The board is 15.125" x 3.125".  As far as the circuit is concerned, I'm going to go over it a couple more times to make sure its correct, and at this stage it would be appreciated if there's anything that jumps out at you that is a wiring problem--sort of like before.  I appreciate your time and help.  Thanks.  Stephen
« Reply #164 on: May 06, 2020, 05:24:23 pm »
can you post the schematic, and your .diy file ?
thanks
dave
Offline wsscott
« Reply #165 on: May 06, 2020, 05:39:28 pm »
Sure.  Its attached.  Stephen
« Reply #166 on: May 06, 2020, 07:12:26 pm »
HA, I have an older version
suggestion, delete the power wires going back to the caps, they're called out at both ends. that cleans up the clutter some.  If you "need" them edit selection to dots, I use dashes for under board.
Offline wsscott
« Reply #167 on: May 07, 2020, 08:29:34 am »
Thanks, I've attached a pdf with the power wires removed.  Do you have any thoughts on whether the turret spacing will work or if they are too close together and would cause difficulty in mounting the caps and resistors, etc.?
« Reply #168 on: May 07, 2020, 09:05:24 am »
Turrets look too close to me, but without a scale reference I can't really say. Ask Doug. He'll know.
I use a 5/16" grid to space turrets on my boards. The only deviation was the AC-15 board which uses a 1/4" grid.
« Reply #169 on: May 07, 2020, 09:17:05 am »
turret spacing
did you use Doug's turrets from this common parts file?
Offline wsscott
« Reply #170 on: May 07, 2020, 09:31:08 am »
Yes, I used the larger one that has a .1" hole and .2" size specification.  Since I've not done or actually seen any turrets before, I don't know what to consider.  Do you know if he builds boards using either size? You know I just realized that the larger one is an "eyelet", and the smaller one is a "turret".  That would make a difference!  Do you know if there's a way to do a global replace in the DIY software so I don't have to go to each turret and change it?  Thanks again.
Offline wsscott
« Reply #171 on: May 07, 2020, 10:12:28 am »
Sluckey, so are you saying that if the turret fits within the boundaries of the 5/16" or 1/4" grid outline, then they will work okay for mounting components being right next to each other without needing any additional space between?
« Reply #172 on: May 07, 2020, 10:24:50 am »
I just realized
yep, did that for a couple, then switched to turrets that Doug made.
I haven't been able to figure out how to "put a box around" (select) a group of components so I can move them as one.  can't "select all" turrets either.
gonna upgrade to latest version n play some today, it's artic freeze coming here!!!
EDIT:
fwiw
played with shift n ctrl keys, figured out if you click a turret, component, etc, then hold ctrl and click a second object, they both "highlight", then you can delete, move as a group.  looks like you can do it with as many objects as you want, didn't figure out how to "replace with"
« Last Edit: May 07, 2020, 10:36:50 am by shooter »
Offline wsscott
« Reply #173 on: May 07, 2020, 10:43:40 am »
What I just tried and worked a few minutes ago is to go into Connectivity section on the left, click on Turret, then right click, Select All.  That then highlights all the turrets, then right click on one of the highlighted turrets, click Edit Selection, and then make the changes, and save.  Seems to work.
« Reply #174 on: May 07, 2020, 12:39:42 pm »
AH, thanks
click on Turret
was that "Doug's" or the Diy one?, I think there's a size difference, but haven't double-checked.
Offline wsscott
« Reply #175 on: May 07, 2020, 01:20:28 pm »
I think it was Doug's.  There is one for turrets and another one for eyelets.  I think maybe the turret is one of his that got added to DIY.
« Reply #176 on: May 07, 2020, 01:26:50 pm »
That's not what I'm saying. I set up a 1/4" grid. Then place my turrets centered on the cross-hairs of the grid, not inside the grid squares. My turrets have cross-hairs on them too and this makes it easy to "snap" the turrets to the grid cross-hairs.
Offline wsscott
« Reply #177 on: May 07, 2020, 01:40:17 pm »
Gotcha!  I'm trying to re-do my layout in DIYLC but can't figure out how to make a global change.  Would like to avoid having to re-do each one of them.  But I'll keep working on it-there ought to be a way.
Offline wsscott
« Reply #178 on: May 07, 2020, 03:30:32 pm »
I was watching one of Doug Hoffman's videos on the DIYLC software and he was talking about the turrets and connecting components to them.  He said that the hole on the top of the turret is very small and its hard to get more than 1 wire in them from the top.  He talked about attaching them by hooking to the sides, but was stressing the point of using turrets to connect jumpers.  My concern is that I've got quite a few connection points with 3-4 wires meeting and wanted to ask if that's going to be a problem for me when I hopefully get to the point of wiring the board.
« Reply #179 on: May 07, 2020, 03:38:59 pm »
3-4 wires meeting
everyone has "their" flavor, mine, more than 3, I add a 2nd turret n jumper
Offline wsscott
« Reply #180 on: May 07, 2020, 04:01:12 pm »
Thanks.
Offline wsscott
« Reply #181 on: May 08, 2020, 04:45:27 pm »
I've gone through the Layout and fixed a couple of my misses, and think everything is now right.  I wanted to ask though if you would mind taking a look at the attached schematic which is the Vibrato control section, and see if my corresponding section on the attached DIY file is correct.  It starts in my Layout in the area to the left of the C cap lead to the board.
I also had a question about the type of Pot for the Vibrato Speed.  I've seen RA type pots used on some circuits and didn't know if there's a reason Sluckey why I don't need that type for this build.  I think you said earlier in this saga that all of the pots are Audio Log.  Thanks.  Stephen
« Reply #182 on: May 08, 2020, 05:52:29 pm »
I'm not allowed to operate heavy equipment, so......
there's a red-ish wire exiting lower left, the other end doesn't go where you have it.
« Reply #183 on: May 08, 2020, 06:05:18 pm »
giving up in the circle, going to paint  :laugh:
Offline wsscott
« Reply #184 on: May 09, 2020, 08:59:19 am »
You're right.  I guess I was tired and missed it.  I think I've got it wired correctly now for the B cap power supply source going to plate 6 of the 12DW7.  I also moved the secondary power source supply going from the C cap, and now it runs from the C cap connection at the 10K on the layout to the other C supply on the 270K.
« Reply #185 on: May 09, 2020, 10:14:44 am »
look inside the circled area AND the schematic, there are 2 330K resistors that come together, ONE .0047uF connects there and goes to ground.
Offline wsscott
« Reply #186 on: May 09, 2020, 12:42:43 pm »
Got it.  I moved the jumper that connects at the bottom on the 330K on the left and goes to the top of the 330K on the right, down to the bottom side of the 330K on the right, where it meets with the .0047uf.
Offline SoundmasterG
« Reply #187 on: May 11, 2020, 12:15:16 am »
I was going to build myself a Revibe, but with the Magnatone vibrato instead of the Fender trem, just like what you are doing. I have enough genuine Magnatone varistors to do it, and enough knowledge to work through what needs to change in the circuit to do it, but I haven't had the time to do it. :) So you might end up getting yours done first. It is an interesting project and I'm eager to see how it turns out wsscott!
Greg
Offline wsscott
« Reply #188 on: May 11, 2020, 08:36:27 am »
Yes, I'm excited to hopefully get to the assembly part of this project soon.  I still keep going back over my Layout.  I've never done a Layout before and its really tedious for me with this circuit.  I don't have much experience overalll.  The only amp I built was the Weber 5F1 kit, but it did work the first time I plugged it in--and its still working.  So I feel if I can get the circuit correctly laid out, then I can build it.  I was going to do the same thing as you by modifying one of the Weber Revibe versions with the Magnatone vibrato, but I was convinced by this forum that it would be better to take the Magnatone M10a circuit, and simplify it by eliminating the second channel, and I also decided to eliminate the tone boost circuit since it already has bass and treble controls, plus its not being built as a stand alone amp.  I want to use the Weber cabinet for the 5H15 Revibe, so that limits my chassis size to 15.5".  But by simplyfying the circuit it looks like it will fit on a 15.125" turret board.  However the Weber chassis won't work because of the cutouts, and CJ at Weber says they don't make custom chassis'. But I have found a company that does one off's with aluminum for about $50, so that should work fine.  I'm going to get a blank chassis and drill the holes.  The Hammond PT that I'm going to use doesn't need a cutout.  So stay tuned.
Offline wsscott
« Reply #189 on: May 12, 2020, 10:22:07 am »
Am I correct that the plates, grids and cathodes on the V6 12AU7 tube are bridged with each other, ie. the 2 plates are bridged with each other, the 2 grids are bridged with each other, and the 2 cathodes are bridged with each other?  If so, can I ask why?
« Reply #190 on: May 12, 2020, 10:31:53 am »
That's correct. It takes a lot of current to drive the reverb tank, more current than that single triode can deliver, so two triodes are paralleled to provide adequate current drive.
Offline wsscott
« Reply #191 on: May 12, 2020, 10:58:30 am »
Thanks.
Offline wsscott
« Reply #192 on: May 12, 2020, 11:36:26 am »
Does anyone know if there's a way that DIY Layout Creator can "test" a layout that's been created for shorts or open circuits?  I'm just trying to find a way to double check what I've created in my layout.  I'm a little gun-shy because I've missed shorts in my previous layouts about 3 times, something I should have caught, and was hoping the software can assist.
Offline wsscott
« Reply #193 on: May 12, 2020, 11:39:57 am »
I'm asking now because I'm about ready to send my layout to Hoffman to create my turret board with turrets installed, and I want to make sure what I've done is correct.  I guess if I discover an error in the board due to my mistake, I can just install myself some extra turrets where needed.
« Reply #194 on: May 12, 2020, 01:04:41 pm »
Your eyes are the only proofreaders you have. I suggest to print the schematic and layout. Then use a highlighter to trace through small portions of the schematic and also trace through the corresponding portions of the layout. Resolve any differences you find. Rinse and repeat until you are confident that the layout agrees with the schematic.
Getting the layout to agree with the schematic is the most time consuming part of a project, especially with a complicated project such as you have. I suspect you'll even dream about layouts before you are done.  :icon_biggrin:
Offline wsscott
« Reply #195 on: May 12, 2020, 01:07:59 pm »
Sluckey-You're right about this being the most difficult part--at least I hope it is.  And yes, I've been dreaming about layouts now for about 4 weeks.  Not every night, but too frequent for my liking!  Thanks.  I'm glad its not just me.
« Reply #196 on: May 12, 2020, 01:36:12 pm »
Just wait 'til you start troubleshooting in your dreams!  :laugh:
« Reply #197 on: May 12, 2020, 03:13:19 pm »
+1
 :laugh:
I've been thanked a couple times by operators that called at 4AM n I "fixed something" in my sleep!!  :sleepy2:
Offline wsscott
« Reply #198 on: May 12, 2020, 04:28:53 pm »
I've done that before too.  Its like you had an "epiphany"!
Offline wsscott
« Reply #199 on: May 13, 2020, 10:42:22 am »
I'm probably going to be ordering my custom turret board from Hoffman today or tomorrow with the turrets installed.  I figure I'll purchase some extra turrets in case I need them.  As to the turret boards, he sells 2 colors, but the black one he says is "non-conductive FR4-G10".  What's the difference in the 2 boards?
Anything I should think of/plan for when ordering the board?
