September 14, 2026, 02:27:46 pm
Hoffman Amps Forum image Author Topic: Input grid resistor  (Read 5123 times)
Offline Vlada
Input grid resistor
« on: March 29, 2020, 03:25:27 pm »
Hi guys, I am building high gain tube preamp and was wondering about V1a grid resistor. Some say lowering this resistor can reduce hiss while others claim that this can lead to overloading input when using overdirve pedals. I am thinking of using 10k resistor with capacitor from tube grid to ground to get the same cutof as with 68k resistor. Are there any other thing to consider? And should I wory about input overloading?
Re: Input grid resistor
« Reply #1 on: March 29, 2020, 03:41:13 pm »
Not very much to say (from my part)
only to remember that a high W rated resistor has the tendency to insert less noise
and ... use a metal film resistor instead of a carbon composition resistor
this will result in less nois at same resistence values
BTW, Mesa, in some amp, didn't used a resistor, they used a ferrite bead, no resistance added and no noise
« Reply #2 on: March 29, 2020, 08:09:00 pm »
> overloading input when using overdrive pedals
Um, so it distorts when you use distortion pedals?
The experiment costs pennies. Just try it.
« Reply #3 on: March 30, 2020, 05:05:56 am »
Tube guitar amps typically use input grid leak resistors and input mixer / grid stopper resistors.
Ok, from the context it’s apparent that this thread is in regard of the grid stopper, but it’s always best to try to avoid folk having to assume relevant info.
To be clear, it’s essential for tubes to have a dc path between their control grid and cathode, with the max resistance of that dc path usually being specified in the tube info.
Offline d95err
« Reply #4 on: March 30, 2020, 06:01:08 am »
Merlin has a good article on the subject:
http://www.valvewizard.co.uk/gridstopper.html
I use his duggestion with a low value input resistor and a capacitor. Works fine and does reduce hiss a bit.
