July 25, 2026, 06:33:13 pm
Hoffman Amps Forum image Author Topic: Belton reverb on engl retro tube  (Read 7290 times)
Offline Nicale19
« on: April 02, 2020, 07:13:05 am »
Hi Guys,
Any suggest is appreciated
It s the btdr-1hm...
Re: Belton reverb on engl retro tube
« Reply #1 on: April 02, 2020, 07:39:19 am »
from all the WEB stuf I read, Belton gets good marks for a box verb
Offline Nicale19
« Reply #2 on: April 02, 2020, 10:34:57 pm »
Any suggest where can i insert circuit?
Offline d95err
« Reply #3 on: April 03, 2020, 12:55:11 am »
In the FX loop is the obvious place.
Offline Nicale19
« Reply #4 on: April 03, 2020, 03:01:16 pm »
Which place exactly, do you think?
« Reply #5 on: April 03, 2020, 03:37:24 pm »
umm, try FX out to verb in, verb out to FX in maybe
Offline Nicale19
« Reply #6 on: April 04, 2020, 11:19:25 pm »
What Do you think here?
« Reply #7 on: April 05, 2020, 08:26:23 am »
does your Belton have jacks for in/out or a glob of wires?  maybe post the datasheet for the brick  :dontknow:
« Reply #8 on: April 05, 2020, 09:39:47 am »
I was recently messin with one of these.
Search this forum for Belton reverb.
There are a couple good threads that helped me out.
Offline Nicale19
« Reply #9 on: April 05, 2020, 02:45:32 pm »
Offline Nicale19
« Reply #10 on: April 05, 2020, 02:46:38 pm »
Last
« Reply #11 on: April 05, 2020, 03:25:48 pm »
looks like you can just solder up 2 1/4 mono plugs, one for in, one for out, wire up your power and plug them into the FX loop on your amp FXout--->belton in  Belton out--->FXin and give it a test run.  I would use shielded wire, or cut a guitar cable in half and solder it up.
« Reply #12 on: April 05, 2020, 06:23:00 pm »
I found this one in my favorites bar:
https://el34world.com/Forum/index.php?topic=23554.0
« Reply #13 on: April 05, 2020, 06:47:35 pm »
 :icon_biggrin:
I saw you there!!
I think I have that one archived, but I was busy  :laugh:
Offline Nicale19
« Reply #14 on: April 05, 2020, 10:49:47 pm »
Thank Guys.. I ll give a look.. Today ill receive the rvb1..i hope ( coronavirus here in Italy is a tragedy)
Offline d95err
« Reply #15 on: April 06, 2020, 04:13:41 am »
Connecting the Belton module between FX send and return should work. The problem as I see it (though this is a matter of taste) is the mixer circuit. The dry signal will be reduced as the Reverb (or FX) level is turned up. With the Reverb/FX knob at max, you have zero dry signal.
I would want the dry signal to remain at a constant level, regardless of the Reverb/FX level. The reverb knob should blend in reverb signal, but not change the dry signal level.
Offline Nicale19
« Reply #16 on: April 10, 2020, 01:46:33 am »
I noticed you are right
I connected "by fly" reverb
Pin 7 +5v pin 5 -ground (from external trasformer)
Pin 4 signal in ( send input from fxloop)
Pin 3 ground from fx in e fx out 6.3mm jack
Pin 1 signal out (return input from fxloop)
No reverb
When i turned up loop level, no sound
It seems reverb is not correctly connected however 🙄
--edit--
1Jack was fault...
Reverb works... But after noon setting (12oclock looop pot) effect is too much... Maybe i ve to use some resistance..
Someone have schematic to use?
« Last Edit: April 10, 2020, 01:25:20 pm by Nicale19 »
Offline davidwpack
    • My music on reverbnation
« Reply #17 on: April 10, 2020, 04:19:28 pm »
Don't know if it would help but this is how it's wired into a pedal.
