August 29, 2026, 04:56:30 pm
Hoffman Amps Forum image Author Topic: Vibro champ ? Switch on intensity pot  (Read 4836 times)
Offline fred
« on: April 03, 2020, 03:38:36 pm »
Hi , I have a pot switch on my deluxe reverb  . when turned off it gives the amp more gain , would this mod work on a  vibro champ .
Its a 80s black  face
Thanks for any input
Fred
Re: Vibro champ ? Switch on intensity pot
« Reply #1 on: April 03, 2020, 04:05:23 pm »
from what I see on the schematic you should get the same "gain" with the pot on 0 and no switch.
« Reply #2 on: April 03, 2020, 06:07:33 pm »
No. The deluxe reverb tremolo circuit is quite different than the VC circuit.
Offline fred
« Reply #3 on: April 03, 2020, 06:19:13 pm »
Thanks for the fast answer back.
« Reply #4 on: April 03, 2020, 06:37:14 pm »
Guess I missed something
"Switch on intensity pot"
does it short to ground the intensity pot, like if pot set to 0?  :dontknow:
Offline fred
« Reply #5 on: April 04, 2020, 10:47:36 pm »
Hi , my understanding is the intensity pot turns off all passing electric , gain and increases gain in the pre tubes .
Something about the regular stock pot takes away some gain from the preamp tube circuit even on 0 .
So on a deluxe reverb if you have a switched pot and it's turned off it adds gain .
I was lookin at the vibro champ wiring , it's not as complex as the deluxe is .
So thanks for the input ..
« Reply #6 on: April 05, 2020, 06:25:02 am »
The 50K INT pot in the AB763 amps puts a heavy load on the signal path. When you disconnect the INT pot with the switch the signal increases because the 50K pot is no longer loading the signal. This results in the signal boost. Of course you no longer have tremolo. This is a popular mod for the AB763 amps.
The VC trem circuit is quite different and this switch mod will not work.
« Reply #7 on: April 05, 2020, 08:20:22 am »
my missing link, thanks  :laugh:
Offline fred
« Reply #8 on: April 05, 2020, 09:44:34 pm »
Thanks sluckey you explained it well .
It is a great mod on the deluxe reverb . I also have the NFB control , called soul control . and if you pull v1 it adds more gain too .
Amps are amazing .
Sluckey , I have that 1940 National amp all up and working great . the field coil does sound nice . I did the rat nest wiring .
It's not pretty , but looks like the 1940s  . thanks again
