August 29, 2026, 04:55:26 pm
Hoffman Amps Forum image Author Topic: AB763 - One Channel - no/tremolo Project  (Read 3957 times)
Offline p2pAmps
    • p2pAmps
« on: April 03, 2020, 05:35:37 pm »
Hello team,
This is a project I'm just starting to play with.  An AB763 / One Channel / no-tremolo.  A few things you will see is the 1M resistor missing in the reverb circuit.  I will be adding a dwell control in place of that thus the extra set of brown and yellow twisted wire.  The 51K resistor you see is a tremolo load resistor.
So...  I am all ears for you experts that see my short comings.  Please come fourth and tell me what I may have missed or just plain messed up.
Cheers and stay safe
Mike
Everything Affects Everything
Re: AB763 - One Channel - no/tremolo Project
« Reply #1 on: April 03, 2020, 05:52:31 pm »
Clean and neat as always. Schematic tells all.
Offline purpletele
    • Vallis Enterprises, Inc.
« Reply #2 on: April 03, 2020, 07:44:24 pm »
Hello team,
Mike
Mike,
What chassis are you going to use?  Are you using a Cap Board and where will you mount it?
« Reply #3 on: April 03, 2020, 08:40:45 pm »
I did a 1-channel AB763 circuit sans verb and trem, and instead of pre-amp attenuation I changed the TS to a James TS, which is set up in such a way to give flat response with pot rotation at 50% and wide range or adjustment for treble and bass. Also has a 'raw' (TS lift) switch for really basic extra grunt.
« Last Edit: April 03, 2020, 08:43:07 pm by tubeswell »
