September 14, 2026, 03:23:30 pm
Hoffman Amps Forum image Author Topic: Pop turning SB, off  (Read 4124 times)
Offline dude
Pop turning SB, off
« on: April 14, 2020, 02:30:01 pm »
This is pretty much a normal thing with amps with a standby switch, turning off the SB, (using as a mute switch) usually with cause a pop. SB switches aren't meant to be a mute switch, anyway. The more l read about SB switches, they aren't needed. Abruptly turning off the high voltage an amp will pop, a normal thing l understand but would a say 600v .047 cap between the rectifier and the standby stop the pop?
Offline 2deaf
  • Now too deaf for 100 watts
Re: Pop turning SB, off
« Reply #1 on: April 14, 2020, 03:36:54 pm »
A 100K/3W resistor across the standby switch contacts works pretty good.
Offline Latole
« Reply #2 on: April 15, 2020, 03:21:50 am »
I always put .0047mfd or 0.01 mfd across SB switch contacts. it work.
Offline d95err
« Reply #3 on: April 15, 2020, 06:28:39 am »
Just rewire it as a real mute circuit (ground the signal somewhere late in the circuit, like just before the PI).
