September 14, 2026, 05:10:13 pm
Hoffman Amps Forum image Author Topic: Twin Reverb repair  (Read 6997 times)
Offline anteriorl5
Twin Reverb repair
« on: April 16, 2020, 09:47:23 am »
Have a 1965 Twin on the bench. It sounded good until heating up, then started to fail. Replaced all the screen grid resistors and found one that fell apart when removing it. Thing is, I checked preamp voltages before the work on the power tube sockets ad everything was close to spec. Now I get 450 volts on the plates of the phase inverter 12AT7. Since the 100K and 82K resistors test good, I'm wondering how this can be. Did I short the tube checking voltages and it is not drawing current? The tube lights up and I do get a very distorted tone testing the inputs with a guitar.
Re: Twin Reverb repair
« Reply #1 on: April 16, 2020, 09:57:09 am »
here's a good start
http://el34world.com/Forum/index.php?topic=23286.0
without hunting I'm not sure, this an AB763 circuit or one earlier ?
did you make sure there was bias volts before heating up the tubes?
450v indicates it's not conducting
Offline anteriorl5
« Reply #2 on: April 16, 2020, 10:57:21 am »
AB763 circuit, mostly original. I will check bias voltage later today.
Offline Latole
« Reply #3 on: April 16, 2020, 01:05:39 pm »
Best is to check bias current ( at cathode ) not voltage.
If no current check bias voltage and tubes,
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #4 on: April 16, 2020, 01:41:30 pm »
Turn the amp off.  Measure resistance from V6 (PI) pins 3/8 to ground.
Offline anteriorl5
« Reply #5 on: April 16, 2020, 04:18:01 pm »
Amp off, resistance from pin 3-8 to ground is 656K.
« Reply #6 on: April 16, 2020, 04:34:07 pm »
That's the problem. Should be roughly 22.5K. Only 3 resistors in series to ground, 470Ω, 22K, and 100Ω. So, you have a bad resistor or a bad connection.
Is this a Reissue amp with printed circuit board?
Offline Latole
« Reply #7 on: April 16, 2020, 05:57:05 pm »
You are right.  Higher resistors= less tube conduction = higher plate voltage
Offline anteriorl5
« Reply #8 on: April 16, 2020, 06:31:23 pm »
No circuit board, thankfully. Original blackface Twin from 1965.
Offline anteriorl5
« Reply #9 on: April 16, 2020, 07:21:27 pm »
Going to order parts. I'm seeing lots of questionable solder joints, all the 100K resistors have drifted higher, a few bad ceramic caps, etc. This will take a little time.
Thanks for the help!
« Reply #10 on: April 16, 2020, 07:31:26 pm »
This should help. I don't suspect the 3 resistors as much as I suspect solder joints, especially the joint to the brass plate ground.
Offline dude
« Reply #11 on: April 16, 2020, 07:46:50 pm »
Possible the tube if solder joints and resistors check out ok, lose pin connections...?
Offline Latole
« Reply #12 on: April 17, 2020, 03:24:19 am »
No IMO. Resistors reading is 25 times higher as they should be.
Offline 2deaf
« Reply #13 on: April 17, 2020, 09:16:57 am »
I'm not betting on the ground connection nor the 100 Ohm resistor because the 820 Ohm NFB resistor offers an alternate path to ground.
Once all of the bets are placed, I suppose the OP could measure the resistance to ground from each side of the 470r, 22K, and 100r resistors.
« Reply #14 on: April 17, 2020, 10:15:44 am »
fwiw;
the 65 SR I fixed had the 100 ohm loose original solder.  3 other original joints in TS and working well.
I did have to "probe", visually near impossible to detect
« Reply #15 on: April 17, 2020, 12:50:19 pm »
I've recently worked on two Silverface SR's, a '72 and '73, and each one had a ground wire on the brass plate pop up (come unsoldered) .
Offline anteriorl5
« Reply #16 on: April 26, 2020, 05:26:46 pm »
Got around to working on the TR finally...turns out there was a 220K resistor where there should have been a 22K. Easy switchout. Voltages are good now and the amp works. Time for a basic service, cleaning sockets and pots, then a few ceramic caps need replaced.
