September 15, 2026, 07:52:55 am
Hoffman Amps Forum image Author Topic: Favorite Bypass Caps? And a question...  (Read 4587 times)
Offline jordan86
« on: April 17, 2020, 06:25:47 pm »
Newbie question...
DO BYPASS CAPS NEED TO BE POLARIZED? A lot of the kits appear to use polarized. My gut says they don't, (like a treble bleed circuit in a guitar) but again, I'm a newbie.
I am ordering my first amp kit here soon. Mojotone Princeton Kit. It seems to use real solid parts, so I'll do it mostly stock with a few tweaks. Probably with a 12" baffle and the Allen TO20. Maybe Paul C mod. I've also been reading about dropping the value of most of the cathode bypass caps in the Princeton to tighten up the lows. I'm somewhat of a noob, but I've been watching a lot of Uncle Doug's videos. The smaller bypass cap value seems to dial back muddiness and the gain just a touch?
4.7uf seems to be a good value (opposed to stock 25uf) but I'm having trouble finding those in like the 50-150v range that are electrolytic, polarized, and have axial leads. Hence my question.
Other Q's...
1) Is there a particular brand you guys like for cathode bypass?
2) Do they have a big effect on tone?
3) Who's your preferred online retailer?
4) I'd gladly welcome any input on that values of 4.7uf vs like a 2uf or 8uf.
THANKS IN ADVANCE!
Edit: Upon further review, it looks mr hoffman himself sells 8uf/150v Spragues and 4.7uf/100v Nichicon. Will those work alright? My understanding is the bypass caps see less than 25v.
« Last Edit: April 18, 2020, 08:45:34 am by jordan86 »
Offline dude
Re: Favorite Bypass Caps? And a question...
« Reply #1 on: April 17, 2020, 06:41:22 pm »
Right here in Doug's parts, scroll down
« Reply #2 on: April 17, 2020, 06:44:09 pm »
any brand flavor is fine, maybe not 1000 for a $, otherwise I use anything.
Ecap is not necessary, just preferred, a 4.7uF non-polarized might get salty.
have 3 ea common 1uF - 25uF, most "V1" tubes have < 3vdc at cathode, most tubes prior to PI, <10vdc, so double and round up to common.
then gator clip, play, next........
« Reply #3 on: April 18, 2020, 12:03:56 am »
NO.
But useful values for audio range 1uFd on up. In this range, electrolytic caps are by far the cheapest type, and work fine for decades.
Non-polar electrolytic costs a little more for no benefit.
Paper and plastic film caps will work fine, are not polar, will last several lifetimes, but a 20uFd film is BIG and COSTLY (even at low voltage).
20uFd 15V e-caps (polar) are a dime apiece in mass production and work fine. (Yes, if you need less than a full crate the price is higher, for picker-labor and because the store never sells-out a broken case.)
