September 15, 2026, 07:53:01 am
Hoffman Amps Forum image Author Topic: how to choose a power transformer?  (Read 5421 times)
Offline j_bruce
« on: May 04, 2020, 01:21:42 pm »
So my Gretsch 6159 project has a bad transformer and I cannot find any specs on the original to try to match it up.
My best contender is a Classic Tone 40-18060 https://www.tubedepot.com/products/classictone-power-transformer-40-18060
which is listed as the one used in the Supro Thunderbolt. I think this might be a good match based on both using two 6L6s and being from the same company and time frame.
What is the typical way to determine what transformer specs are needed?
Thanks for any help,
Jerry
Re: how to choose a power transformer?
« Reply #2 on: May 04, 2020, 03:13:00 pm »
See my comments in your other thread about this amp.
« Reply #3 on: May 04, 2020, 03:18:01 pm »
+1
many ways, I start;
add up all the tubes filament current from datasheet, .3A+.6A+....
a schematic with PA plate VDC is GREAT thing, if not;
PA tube datasheet, "typical operations" pushpull, or SE
find plate volts, current zero signal X number of PA tubes
call it 400vdc plate, (.04A X 2 tubes) = 80mA + ~ (4mA X 3 small tubes) == 102mA
decide type of rectifier, say full wave bridge;
so 400/1.414 ~280 VAC @ ~~120mA with call it 3A filament winding
OR
find any amp close with same PA tubes and about the same small tubes that you can find a part# for and go the easy route  :icon_biggrin:
Offline j_bruce
« Reply #4 on: May 04, 2020, 04:27:03 pm »
https://el34world.com/Forum/index.php?topic=16664.0
That taught me what I needed to know. I really should do a better search before posting!
Shooter's typical operations approach matches it well.
400v/1.414 ~280v preferred
2 6L6 + 4 12ax7 = 140 + 16 = 156mA
heaters  2*.9 + 4*.3 =3A
This one looks like a good fit: http://www.classictone.net/40-18103.pdf
Jerry
Cheers,
Jerry
« Last Edit: May 04, 2020, 05:07:50 pm by j_bruce »
Offline Latole
« Reply #5 on: May 05, 2020, 03:26:43 am »
Cheers,
Jerry
Google have all the answer...most of the time :laugh:
