July 28, 2026, 07:08:08 am
Hoffman Amps Forum image Author Topic: Can I use this Pt for the Sluckey's Dual lite build?  (Read 3959 times)
Offline silat
« on: May 06, 2020, 10:53:53 pm »
Can I use this Power Transformer for the Dula-lite the 25 V red wires are throwing me off.
https://www.mouser.com/datasheet/2/177/290CZ-1841470.pdf
Re: Can I use this Pt for the Sluckey's Dual lite build?
« Reply #1 on: May 07, 2020, 06:13:49 am »
no really. not keeping s. lucky's plan as there's no 5V winding and with SS rectifiers, you'd have just over 400V B+. yes, you could use 6V tube rectifier but with a 6CA4 you'd have around 375V B+. 6BW4 (EZ80) around 350V.
hammond 270EX or the classictone 18W set would be better choices. mojone sells heyboer parts 18W PT is laydown only like the original.
https://www.hammfg.com/files/parts/pdf/270EX.pdf
http://www.classictone.net/40-18056.pdf  upright version.
http://www.classictone.net/40-18035.pdf  laydown version.
https://www.mojotone.com/amp-parts/Power-Transformers/British-Style-18-Watt-Power-Transformer
« Last Edit: May 07, 2020, 06:23:38 am by DummyLoad »
Offline silat
« Reply #2 on: May 07, 2020, 12:02:43 pm »
Thanks DL,
I ordered the Hammond 207EX . I do not know what I was thinking, my Dyslexia must have kicked in? I did not even see the 25 volts until  later on  when I started putting it together..  I must have seen 5 Volts instead of 25.  It was giving me fits.
 :BangHead:
« Last Edit: May 08, 2020, 12:40:55 am by silat »
