September 15, 2026, 05:00:28 pm
Hoffman Amps Forum image Author Topic: no vibrato fender vibroverb  (Read 4590 times)
Offline Stevewdewitt
  • I love building tube amps
    • DeWitt Amps
« on: May 12, 2020, 10:41:00 pm »
Hello,
I have come into possession of what I think is a 63ish Fender Vibroverb. It was in rough shape. Recapped the electrolytics. The reverb tank needs help. the reverb works fine with a new tank. The vibrato isn't working. The thing was modded heavily around the vibrato section of the amp. I put it all back to stock. Voltages on the tube are really close to the voltages on the schematic. I had to replace the roach it was in bad shape. I replaced the caps for the tremolo. I have traced this out and it seems fine.
I have a pedal I made for another amp that I used for the vibrato pedal. The tremolo still doesn't work. I replaced the tube with a new 12ax7.
I attached some photos.
TIA,
Steve
Steve
    • DeWitt Amps
Re: no vibrato fender vibroverb
« Reply #1 on: May 12, 2020, 10:52:44 pm »
Some before photos so you can get an idea of what I was dealing with.
I have played it and it sounds good. I haven't gotten to turn it up.
Steve
Offline vampwizzard
    • Walbertedwards.com
« Reply #2 on: May 12, 2020, 11:40:52 pm »
Its come a long way! great restoration.
As far as the trem circuit goes: assuming the wiring is correct etc, some of the blackfaces need a shorting jack in lieu of the proper footswitch: https://www.youtube.com/watch?v=C6jGHPS-Zhw
If youre not using the original style footswitch who knows if its wired right.
Good luck!
    • DeWitt Amps
« Reply #3 on: May 13, 2020, 08:01:45 am »
I will give it a try
thanks
Steve
    • DeWitt Amps
« Reply #4 on: May 13, 2020, 01:37:33 pm »
Fixed it. I mistakenly put a .002 cap in place of the .02 cap.
thanks,
Steve
« Last Edit: May 13, 2020, 01:55:18 pm by Stevewdewitt »
Steve
Offline vampwizzard
« Reply #5 on: May 13, 2020, 07:49:31 pm »
hey now! even better that you figured it out.
Take a video of the thing playing? Havent seen too many vibroverbs in the wild.
