September 15, 2026, 06:53:46 am
Hoffman Amps Forum image Author Topic: Just finished a new D'mars overdrive  (Read 6037 times)
Offline Tone Junkie
« on: May 14, 2020, 05:14:27 am »
 Great amp super clean channel. went with a James tonestack on both the clean and overdrive channel. Did a solid state CF on both . For some reason having trouble with the dumble style effects loop usually works right out of the gate . Have sound into and out of the first stage but when it goes thru the 1.8K resistor no sound . Changed the  resistor no help. other than that great sounding amp didn't use the 5879 tube messed with the bloom a bit but still a great sounding overdrive .
Thanks Bill
« Last Edit: May 14, 2020, 03:04:45 pm by Tone Junkie »
Re: Just finished a new D'mars overdrive
« Reply #1 on: May 14, 2020, 06:55:32 am »
Not sure what this means?  1st stage of preamp?  1st stage of FX?
It would have sure helped IF you had posted an accurate schematic of the amp in it's current state?
So, my response is going to be based on the assumption that the entire amp works fine except the FX loop. In other words, the clean and overdrive channel are functioning properly.
* see the attached trouble shooting ideas and try those and then try the suggestions below:
1) Check voltages on fx
2) check send and return jacks
3) check pots
4) quadruple check your wiring & check for continuity
With respect,Tubenit
« Reply #2 on: May 14, 2020, 07:52:26 am »
How close is this to what you have in your D'Mars?   Can  you edit this to what you actually have?  I've attached an editable ExpressSCH version for you.
Can you provide an accurate schematic of the amp in it's current state, please?
Offline Tone Junkie
« Reply #3 on: May 14, 2020, 03:04:08 pm »
Tubnit see in V3a  on the schematic you put up were it comes out of #3 on the tube and then runs into a 1.8k resistor. Then branches of to the send pot. for the effects loop. With my signal tracer I can listen to the signal going into V3a and coming out of  pin number #3, stronger as it should be. But on the other side of the 1.8k resistor no signal.That schematic is pretty close other than the tone stack on the overdrive side is after the solid state CF after the second stage.
« Last Edit: May 14, 2020, 03:23:09 pm by Tone Junkie »
Offline Tone Junkie
« Reply #4 on: May 14, 2020, 03:07:52 pm »
Tubnit bunch of good ideas will check the 27k being grounded first. Thanks Bill
Offline Tone Junkie
« Reply #5 on: May 14, 2020, 03:21:25 pm »
Good call on the 27K resistor. might be bad, reading no resistance in circuit, But stranger still reading as an open short to ground thru the resistor. I was tired last night and needed a fresh eyes on this . Will change it out when I get home from work.  thank you
« Reply #6 on: May 14, 2020, 03:45:30 pm »
Open short to ground??? What does that mean? How is that displayed on your meter?
« Reply #7 on: May 14, 2020, 07:51:39 pm »
I'm thinking he means it doesn't have continuity to ground??
Offline Tone Junkie
« Reply #8 on: May 14, 2020, 10:45:14 pm »
Sorry guys i misspoke ,Trying to hurry out the door to work . Kids talking to me at the same time. With my tester it showed continuaty strait thru the resistor which it shouldn't do .when i measured  the resistance it didn't register,usually in circuit it might show the wrong resistance because of other factors but always shows something . So im going to change that out when i get home .Thanks Bill
« Last Edit: May 14, 2020, 11:09:40 pm by Tone Junkie »
Offline Tone Junkie
« Reply #9 on: May 15, 2020, 04:47:23 am »
Got it. I had used a 5 lug terminal strip in a couple places . This one mounted in the middle which made that lug grounded. Tied my whole circuit to grounded lug which stopped the sound right there. LOL
Thanks Guys PS amp sounds fantastic cant wait to crank her up tomorrow.
Will put some pictures up when I get her in the 1x12 cab.
« Reply #10 on: May 15, 2020, 05:24:01 am »
You're not the first person to tie a circuit by mistake to a terminal ground lug.  :icon_biggrin:
Anything that you're willing to share in the way of photos, schematic, sound clips or specific critique of tone would be valued.   :thumbsup:
