September 08, 2026, 03:50:14 pm
Hoffman Amps Forum image Author Topic: no sound in this amp  (Read 4833 times)
Offline Geezer
« on: June 18, 2005, 05:31:43 am »
        > no sound in this amp
<< Prev Topic | Next Topic >>
Author  Comment
gurusimran
(3/17/04 1:06 pm)
 I turned on this plexi with no ground connection.
it did a sound for 1 second then nothing more.
Then I tried again but there´s no sound.
Only a little bit when I turned the volume a 9.
How can I fix it?
GroundhogKen
Forum Moderator
(3/17/04 1:12 pm)
 Re: no sound in this amp
 Any blown fuses?
Do any tube plates get red?
Do the heaters glow and tubes get warm in standby?
No hiss, no hum, no static, nothing?
Any sign of burned components?
Can you post the tube voltages?
Preamp tube pins 1,2,3,6,7,8
Power tube pins 1,3,4,5,6,8
Ken
wayneosdias
Senior tube assistant
(3/17/04 4:55 pm)
 Ken
your too nice.
gurusimran
(3/18/04 4:30 pm)
The heaters works fine.
The plates are normal.
No hiss, no hum, no static nothing.
Only the guitar sound at around 9 on volume but extremely quiet.
The pins votages are
v1: pin1 131v, pin2 0v, pin 3 843mv, pin6 147v, pin7 0v, pin 8 2.4v
v2:pin1 1.65v, pin2 3.4v, pin3 2.12v, pin6 269v, pin7 9.4v, pin8 12.5v
v3:pin1 202v, pin2 1v, pin3 36v, pin6 196v, pin7 12v pin8 36v
v4:pin1 1.3mv, pin3 440v, pin4 400v, pin5 -40v, pin6 452v, pin8 1.5 mv
v5: pin1 1.4mv, pin3 455v, pin4 454v, pin5 -40v, pin6 454v, pin8 1.4mv
GroundhogKen
Forum Moderator
(3/18/04 4:44 pm)
Check your components and connections.
V2 pin 1 should exactly equal V2 pin 7 because the pins are wired together.
Go back and check your work carefully.
As you find errors, fix them and re-post the new pin voltages.
Ken
gurusimran
(3/18/04 11:02 pm)
 v2: pin1 9.4v, pin7 9.4v
I'll check the components and conections now.
6bq5
Junior tube assistant
(3/20/04 9:51 pm)
 hello there, if those voltages for v2 pins 1 and 7 are correct, you probably have a bad 100k plate resistor--the one mounted on the v2 socket. change it out and see what you get. hope this helps. rh
 Topic Commands
Powered By ezboard® Ver. 7.32
