August 29, 2026, 04:56:28 pm
Hoffman Amps Forum image Author Topic: B+ question  (Read 9022 times)
Offline newguitarsmell
B+ question
« on: May 18, 2020, 01:34:22 pm »
I'm working on a 5e3 and a resistor keeps burning up and my B+ is way to high...
« Last Edit: May 18, 2020, 01:42:37 pm by sluckey »
Re: B+ question
« Reply #1 on: May 18, 2020, 01:35:21 pm »
Sorry for the duplication of the pic....
I tried two different rectifier tubes. I'm thinking I'm not getting any signal?
Offline labb
Re: B+ question
« Reply #2 on: May 18, 2020, 01:45:58 pm »
Probably a short to ground to fry the resistor. Check around V1 and  V2. One or both of those tubes may be bad. and check C12.
« Last Edit: May 18, 2020, 01:49:36 pm by labb »
Re: B+ question
« Reply #3 on: May 18, 2020, 01:47:36 pm »
Is C12 installed backwards? If not, use your ohm meter to check for a short from positive side of C12 to chassis. The short may be C12 or it may be in the wiring connected to C12.
Re: B+ question
« Reply #4 on: May 24, 2020, 03:52:43 pm »
Hi Guys
I managed to rewire whatever it was that was shorting my Cap and frying my resistor - win.
I redid my bus bar - seems OK. The amp fires up - the voltages are in normal range. I assume this means I didn't fry my PT.
Nice hum (low) to the speaker but no signal. I checked the tubes, I checked the cord..
Gut shots here - I don't know how you guys make your amps look so wonderful and my gut shots look like a war zone - getting better, but still. apologies for dog hair.
Re: B+ question
« Reply #5 on: May 24, 2020, 03:54:12 pm »
guts
Re: B+ question
« Reply #6 on: May 24, 2020, 03:55:05 pm »
guts
Re: B+ question
« Reply #7 on: May 24, 2020, 03:55:55 pm »
more
Re: B+ question
« Reply #8 on: May 24, 2020, 04:02:11 pm »
I can hear the volume pots effecting the hum of the speaker - and I can also clearly hear the tone pot is effecting the quality.
I think it's something simple - it's like the guitar just isn't plugged in - I will go back to it after lunch break. Maybe I will see it then..
 :BangHead: :BangHead:
Re: B+ question PLEASE HELP
« Reply #9 on: May 24, 2020, 05:58:14 pm »
I realized I had a short in one shielded wires... and my numbers are no good
PLEASE HELP. My voltages are in Green
I am using Classic Tone 40-18090 OT and Classictone 18021 PT
Offline vampwizzard
    • Walbertedwards.com
Re: B+ question
« Reply #10 on: May 24, 2020, 06:07:58 pm »
theyre close. Are you sure the filter caps and power resistors are still ok? what rectifier tube are you using?
Offline 66Strat
Re: B+ question
« Reply #11 on: May 24, 2020, 06:11:08 pm »
IMO, the problem lies with the power transformer. It is rated to deliver 710 volts under a 100 mA load. Vintage 5E3 power transformers were rated at about 700 volts (350-0-350) in a no load condition.
Edited to add verbiage.
You need a power transform that delivers about 650 volts under load (325-0-325).
http://www.classictone.net/40-18021.pdf
« Last Edit: May 24, 2020, 06:16:46 pm by 66Strat »
Regards,
JT
Re: B+ question
« Reply #12 on: May 24, 2020, 06:18:18 pm »
I expect to see voltages like that when you use that Classictone 18021 PT. However, I see you are using a 560Ω cathode resistor. Why??? Should be 250Ω. Using that 560Ω resistor causes the output tubes to run cooler Running the output tubes cooler means the B+ is not being loaded much. Change for 250Ω/10W and voltages should drop a bit.
Re: B+ question
« Reply #13 on: May 24, 2020, 06:25:27 pm »
Hi e - I replaced it after I took the pictures. It is now 250 Ohms/10W I thought about that, too. but the voltages are still so high! Is it because there is basically no signal
load?
Re: B+ question
« Reply #14 on: May 24, 2020, 06:28:34 pm »
no
Re: B+ question
« Reply #15 on: May 24, 2020, 06:30:14 pm »
When I was sorting out the BBQ resistor , Sluckey said my Cap was shorted to ground. That was exactly right. At that point I pulled all the Capacitors and made sure they were all still good. I have checked each of my connections for conductivity - I redid the input section and found 1 shorted wire which I fixed... It seems SO close to working.
I feel like it's something so stupid I'm just not seeing it.
M
Re: B+ question
« Reply #16 on: May 24, 2020, 06:31:53 pm »
I will shoot another picture of the input area.
Re: B+ question
« Reply #17 on: May 24, 2020, 06:36:06 pm »
more
Re: B+ question
« Reply #18 on: May 24, 2020, 06:36:54 pm »
another
Offline 66Strat
Re: B+ question
« Reply #19 on: May 24, 2020, 06:38:21 pm »
load?
No.
Tubes draw current. At idle, a 5E3 should draw about 80 mA of current, 100 mA at clipping. This is the load seen by the power transformer. The resistance in a power transformer's primary and secondary windings will cause the "no load" voltage of the power transformer to "sag" down to the voltage under load rating.
Regards,
JT
Re: B+ question
« Reply #20 on: May 24, 2020, 06:42:18 pm »
The 5y3 tube is a new Sovtek one. I tested all the tubes on my tester and every one works perfectly. I have wired something wonky and I can’t find it. Poo
Re: B+ question
« Reply #21 on: May 24, 2020, 06:45:41 pm »
Get a real NOS 5Y3. B+ voltage will decrease.
Re: B+ question
« Reply #22 on: May 24, 2020, 06:51:33 pm »
I have one so I will try that. I doubt that will solve my no signal problem.. will report back...thanks for all the help guys. I’m almost ready to take it out back and shoot it.
Re: B+ question
« Reply #23 on: May 24, 2020, 06:56:45 pm »
I agree. No signal is a separate problem. Probably a wiring error.
I don't consider your voltage reading to be a problem.
Re: B+ question
« Reply #24 on: May 24, 2020, 07:44:06 pm »
Someone want to double check, I'm coming up with 19W a tube using green numbers and 250ohm  :dontknow:
Offline 66Strat
Re: B+ question
« Reply #25 on: May 24, 2020, 08:08:20 pm »
load?
No.
Pffft , pffft, Testing...Testing....doing my best spit on mike impersonation
Regards,
JT
Re: B+ question
« Reply #26 on: May 24, 2020, 08:12:16 pm »
 :laugh:
the amp can operate at 437vdc, but not at 19W
Re: B+ question
« Reply #27 on: May 24, 2020, 11:55:19 pm »
Thanks everyone for the encouragement. It WORKS and sounds Wonderful.
I have almost no idea what the deal was but I suspect something under the board - something shorting to the chassis? Who knows. Maybe I just had to pay my dues. All the info you all helped me with today really helped me figure out what it WAS NOT - I wish it. hadn't taken me four or five hours of head scratching to get here - but done is done and it sounds great. I replaced the rectifier with a NOS one and that helped - and I added a choke which helped more.
Someday, I hope, it won't be such a royal pain in the booty.
