September 15, 2026, 01:13:07 am
Hoffman Amps Forum image Author Topic: how much power does a fixed bias trimpot need to handle  (Read 8556 times)
Offline tnmgcarbide
« on: May 20, 2020, 07:43:20 pm »
i've seen them from teeny , 1/8 w trimmers  to massive Clarostats
 and Allen-Bradleys........ how much power do they pass in a
50, or 100 watt tube amp ?  the mil-spec components sure look cool inside the chassis,  but  $10 toward a  better  celestion or jensen goes a lot further.  what's  the ideal trimpot in a 6l6 or el34
 design?
Re: how much power does a fixed bias trimpot need to handle
« Reply #1 on: May 20, 2020, 09:00:49 pm »
Its pretty easy to work out if you look at a schematic that has voltages marked on the bias supply.
Power = Voltage x current
and
Current = Voltage/Resistance
So if you know the voltage and resistance, then
Power = Voltage x (Voltage/Resistance) = Voltage x Voltage / Resistance = Voltage^2/Resistance
Usually, you rate the power rating of a component to handle at least 2 x the maximum power 'seen' by the component.
So the power rating of any component is 2 x (Voltage^2/Resistance)
Offline tnmgcarbide
« Reply #2 on: May 21, 2020, 01:54:02 pm »
thanks for the update to  ohm's law .
my question was more : would a bigger resistor be beneficial in the circuit, or a waste of money.
cheers, it was a good answer, but  not practical.
« Reply #3 on: May 21, 2020, 02:46:15 pm »
   there is very little current in the bias ckt as it is basically a "potential" on the grid.. I wouldn't worry about it..   trim pot or regular pot  or a super grade pot..   Doug uses little piher trim pots..  why would he
use that part if it wasn't acceptable?
btw   I think tubeswells answer was about as practical as one can get in electronics and a given circuit.
« Last Edit: May 21, 2020, 03:01:03 pm by mresistor »
« Reply #4 on: May 21, 2020, 02:48:13 pm »
does a Yugo and a Bentley both get you to the grocery store?
since you already know they both meet ohm's requirements, I'd call it dealers choice  :icon_biggrin:
« Reply #5 on: May 21, 2020, 03:02:38 pm »
Yes  but from first hand experience the yugo may get you there .. but due to terrible brakes you may over shoot the store..
« Last Edit: May 21, 2020, 05:38:27 pm by mresistor »
« Reply #6 on: May 21, 2020, 03:14:11 pm »
 :laugh:
The only one I "played with" was in a field and needed drug out for scrap, it broke into smaller pieces, but I got it ready for the scrapers  :icon_biggrin:
« Reply #7 on: May 21, 2020, 05:39:07 pm »
well  to the Yugos credit   I might have been thinking of a Lada..
Offline tnmgcarbide
« Reply #8 on: May 21, 2020, 06:01:03 pm »
don't forget the lubricant . try some 2-26 from crc . i hate to be dry
when i get the reach around.
Offline 66Strat
« Reply #9 on: May 21, 2020, 06:12:04 pm »
:laugh:
I had a field car when I was 15. My best friend and I laid out a 1/4 oval track at the farm and practiced our dirt track skills. :icon_biggrin:
Regards,
JT
Offline Dave
« Reply #10 on: May 21, 2020, 06:15:29 pm »
Mresistor, not that I doubt anyone's connection to the foreign car market, but I bet you could count the number of people on this forum who know what a Lada is on one hand.
Not that they are missing much. I rented one years ago and some guy pulled out in front of me so I sounded the horn which was mounted in the trunk. I almost crashed anyway.
« Reply #11 on: May 21, 2020, 06:53:18 pm »
I built a go-cart track for the kids, ~~400' X 50' oval_ish
fwd 10 years and I was running my jeeps on it, then the WRX on it, dialing my eye to hand, the record, 37mph on the back straight WITHOUT leaving track  :icon_biggrin:
***Manual transmissions ONLY ***   :laugh:
« Reply #12 on: May 21, 2020, 08:14:46 pm »
The one I was in was in Holland in the 80's  and the person that owned it said it had Breznev brakes..     LOL    it was a soviet tin can..   they were using the car to smuggle bibles into the USSR>
https://en.wikipedia.org/wiki/Lada
Offline tnmgcarbide
« Reply #13 on: May 21, 2020, 08:58:32 pm »
m
useless
how's this...
does a push-pull 6aq5 need in   p-p a different OT inductance  than an el84 p-p?   10k vs 7k ? or the reverse ?
« Last Edit: May 22, 2020, 11:04:24 am by tnmgcarbide »
Offline Latole
« Reply #14 on: May 22, 2020, 03:10:32 am »
  I always put multi tour Cernet pot on fixed bias amp.
« Reply #15 on: May 22, 2020, 09:45:44 am »
looking at the datasheets, something ~ 8K works for either
Offline tnmgcarbide
« Reply #16 on: May 22, 2020, 10:56:38 am »
thanks .
 i know the only truth is to test in the circuit itself, but i
 don't  need to reinvent the candle... thomas edistone
you guys re great . thanks to all who post here , i'm happy to
get any and all information .
cheers
« Last Edit: May 22, 2020, 11:03:32 am by tnmgcarbide »
