September 15, 2026, 06:06:27 am
Hoffman Amps Forum image Author Topic: Extremely high B+ throughout whole amp  (Read 7736 times)
Offline clyde
« on: May 22, 2020, 02:39:53 pm »
Princeton AA964 build, my first in awhile due to relocation and health issues.  On a Filmosound chassis, I had this issue previously and left it for awhile, redid the power supply and it fired up this morning, beautiful.  I changed out tubes and now I have 498v throughout the amp, plates, screens preamp everywhere.  I'm thinking something isn't grounding, internal to the PT?  The PT is Filmosound original 360-0-360, but with a 5Y3 it was almost dead-on to factory AA964 voltages earlier today.
Offline Dave
Re: Extremely high B+ throughout whole amp
« Reply #1 on: May 22, 2020, 02:48:16 pm »
Are you sure that when you changed the tubes that you didn't stick in a 5AR4 by mistake?
Dave
Offline labb
« Reply #2 on: May 22, 2020, 03:20:00 pm »
That number would indicate that none of the tubes are conducting. It is as though you have no tubes installed.
Offline Latole
« Reply #3 on: May 22, 2020, 03:32:02 pm »
Princeton A964 schematic show PT 340-0-340 volts. You have 20 volts over on both side.
And what is the current (power ) of this PT ? For Princeton you need no more than 70 ma
You PT could be too powerfull and may fit with Tremolux or Vibrolux who need same voltage with 180 ma ?
Or 6V6 bias is too cold ?
I often use zener diodes to reduce B+ voltage when I built amp from scratch.
Zener diodes for reducing B+
https://robrobinette.com/Generic_Tube_Amp_Mods.htm#B+1_Voltage
https://el34world.com/Forum/index.php?topic=25996.0
https://el34world.com/Forum/index.php?topic=17595.0
https://www.tedweber.com/v-dump
« Last Edit: May 22, 2020, 03:40:49 pm by Latole »
Offline Latole
« Reply #4 on: May 22, 2020, 03:33:14 pm »
+1
Or Power supply see no tubes. ?
Offline 2deaf
  • Now too deaf for 100 watts
« Reply #5 on: May 22, 2020, 04:40:15 pm »
Are the heaters lighting up?
Offline Williamblake
« Reply #6 on: May 22, 2020, 05:07:49 pm »
And what heater voltage are you reading?
Offline clyde
« Reply #7 on: May 22, 2020, 06:12:49 pm »
Heater volts are fine, bias voltage is fine.  500v more or less at every B+ node, dropping resistors do nothing.
« Reply #8 on: May 22, 2020, 06:44:14 pm »
Then suspect you’ve missed a critical signal ground connection. With your R-meter, check for DC-continuity between each (lead of every component* with a) ground return lead, and the chassis. You’re looking for open readings
*including all the filter caps, grid leak resistors, cathode resistors and volume pots etc
Offline labb
« Reply #9 on: May 22, 2020, 08:35:44 pm »
What Tubeswell said..what is your grounding scheme? First check I would make would be from the cathode pin of each tube to ground.to the chassis, not your ground point connection.  Do with the power turned off to the amp.
Offline clyde
« Reply #10 on: May 23, 2020, 11:45:52 am »
Thanks guys, I suspected it was grounding somewhere.  This is not my first rodeo by far.  I'll ground every connection by clip lead and get back to you.  Darn!
Offline clyde
« Reply #11 on: May 23, 2020, 03:40:03 pm »
Heater wire was floating around in one of the pins loose, made contact just often enough to piss me off.  After a long layoff I've lost my edge.  Thanks everyone!
